Author Topic: Fuel tank pressure?  (Read 1039 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
Fuel tank pressure?
« on: July 22, 2010 - 06:02:26 PM »
When I go for a drive an get fuel I always have pressure in my tank when I release the cap. Is this normal? If not I guess my breather is blocked? Any ideas?
Re: Fuel tank pressure?
« Reply #1 on: July 22, 2010 - 06:37:19 PM »
Yes, that is not good.
My breather is apparently blocked too, so I drilled a small hole in my gas cap, but I have the flip-top type, so nobody knows.   :naughty:
I had fuel starvation issues to clue me in. You haven't yet?
« Reply #2 on: July 22, 2010 - 08:57:22 PM »
They do make vented and non-vented gas caps?
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: July 23, 2010 - 04:56:14 AM »
I too have pressure on the gas cap when I open it.  I also had fuel starvation issues but that was from when I installed my TQ carb and I blocked the hoses that vented the carb bowl.  Starvation went away after re-connecting the hoses.
But the pressure on the tank is always there.  Just like when you open a gallon gas can to fill the lawn mower.  I was getting raw gas up to my charcoal canister, so I removed the 'fuel tank vent line' hose from the canister.  Anyway, what issues will pressure on the tank cause?
« Last Edit: July 23, 2010 - 05:13:34 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline hooD
  • detroit iron
« Reply #4 on: July 23, 2010 - 04:58:25 AM »
this may help. but the caps say they are vacuum vented.
http://www.cuda-challenger.com/cc/index.php?topic=70329.msg719307#msg719307
-Larry
1973 'CUDA 340
original owner
37,117 miles
« Reply #5 on: July 23, 2010 - 12:29:21 PM »
pressure in the tank is not as much of an issue , at least the fuel will be forced up to the pump so the pump doesn`t have to work as hard , but the tank should be vented
