Author Topic: plug wires, distributor  (Read 1186 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: July 22, 2010 - 11:15:53 PM »
Like an idiot, I removed my plug wires and distributor with out marking anything. I have since rotated the engine so I have a 50/50 chance on putting the distributor in wrong. is there any type of diagram that I can look at to put the plug wires on to the correct place on the distributor? Any help would be appreciated.
Re: plug wires, distributor
« Reply #1 on: July 23, 2010 - 02:27:40 AM »
the plug wires can go anywhere on the cap
so you need to pull #1 spark plug & stick your finger in the hole & crank the engine over until you feel pressure then bring the timing mark up to TDC & install the dist with the rotor point to where #1 wire is on the cap , re-install the plug
« Reply #2 on: July 23, 2010 - 09:02:44 AM »
I see. So that will take care of it possible being 180 degree's off. Just curious, where is the #1 plug located on the block and the where is it on the rotor? Thanks for your help
« Reply #3 on: July 23, 2010 - 09:12:57 AM »
« Reply #4 on: July 23, 2010 - 12:47:52 PM »
If you look at your engine, #1 cylinder is always located
furthest ahead. If you look at your Valve Covers, you will see that the Left side valve cover leads the Right Side by a measurable and very noticable difference.
Also, when cranking over the engine with your finger in #1 spark plug hole, make sure the coil wire to distributor is removed so the engine doesn't start (for safety and very obvious).
« Reply #5 on: July 23, 2010 - 06:03:10 PM »
Cool! Thanks. So with the cap off, I turn the metal point of the distributor to the #1 spot and make sure that plug wire goes to the #1 plug?
« Reply #6 on: July 23, 2010 - 08:31:55 PM »
Righto as long as #1 cylinder is at TDC....you want to point it 10-15 degrees before(roughly 1/2 way between 2&1) so your timing will be close enough to start easy.
« Last Edit: July 23, 2010 - 08:33:28 PM by Bullitt- »
« Reply #7 on: July 26, 2010 - 09:14:30 AM »
not quite , bump tythe engine over until you have at TDC # 1 ,then the dist will drop in facing in either of 2 positions , then connect #1 wire where the rotor is pointed & adjust the body of the dist so the reluctor lines uo with the pick up coil & adjust timing once it is running
