Author Topic: Traction needed  (Read 4734 times)
Offline Cuda54
Traction needed
« on: July 23, 2010 - 01:04:40 AM »
I have a 1972 Cuda with a 525hp 440-6 auto with 3.23 gears with traction bars. L-60-15s on the rear and it still burns tires hard I would like to get it to hookup better any ideas? :burnout:
Re: Traction needed
« Reply #1 on: July 23, 2010 - 02:41:19 AM »
better tires makes a huge difference Try a Nitto DOT Drag radial
 other than that clamping the front section of the springs helps , the best raction I have ever had was with a 32" ladderbar set up , the front wheels had trouble staying on the ground that way .
  have not seen any improvemnts using Caltrac systems
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Traction needed
« Reply #2 on: July 23, 2010 - 09:06:59 AM »
Sticky tires and getting wieght transfer are the keys.Street driven a lot?depending on how the car is driven you might get by with 70/30 front shocks and maybe softer torsion bars.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline hotrod98
    • Maniac Musclecars
Re: Traction needed
« Reply #3 on: July 23, 2010 - 11:22:24 AM »
Change the rear springs out for super stock springs and use the Rancho adjustable shocks from Caltrac. Set the left side one notch stiffer than the right. You need to add a pinion snubber. My 71 Cuda street radial car is set up this way and hooks hard with street tires.
My Pro/No-E 71 Cuda is set up the same way but will soon have a four link setup.
At some point you have to decide whether you want a good riding streetable car or a drag car.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline vinb
Re: Traction needed
« Reply #4 on: July 23, 2010 - 06:08:03 PM »
14"x32" Slicks and a ladder-bar or four-link would be nice....
Don't forget the wheelie bars..
 :2thumbs:
Offline Cuda54
Re: Traction needed
« Reply #5 on: July 23, 2010 - 06:15:56 PM »
Well I do have the super stock spring on too. Which would be better AlterKtion or ladder bars or a 4 link? I just ordered a set of 15x8" Crager SS to get more rubber on the ground. The radials I have on now seam a little hard that might be some of it too. Looking for a cool cruiser and the drag strip is only 5 miles from my house. So I will go play over there too. I have a set of ET drag tires for that but I have not tried them out yet.
Offline hotrod98
    • Maniac Musclecars
Re: Traction needed
« Reply #6 on: July 23, 2010 - 08:57:44 PM »
Most of the really consistent cars at our track run four link. You would need to back-halve the car though to convert to four link properly. One of my 71's has been back-halved but still has the super stock setup...for now.
You might try adding 75 lbs of weight in the trunk. Bolted down properly of course. Be sure and check your pinion angle every time you make any change to the suspension.
1971 Cuda Drag Car
Offline Cooter
    • christinecarclub.com
Re: Traction needed
« Reply #7 on: July 23, 2010 - 10:11:56 PM »
If I'm not mistaken, Ladder Bars need a Floater set up to operate properly on a leaf spring car. Alot of work IMO...
I've had the best luck with Hoosier tires...Hook like hell, but you don't want to try for a mileage records though.
Offline Cuda54
Re: Traction needed
« Reply #8 on: July 23, 2010 - 11:24:42 PM »
It is not setting any mileage records now. It is a race tho between the tach and speedo going up and the gas gage going down. :bigsmile:
Offline cudadave72
  • you motorboatin sob!!!
Re: Traction needed
« Reply #9 on: July 25, 2010 - 09:53:42 PM »
My Cuda has very simular power. At first I had some regular radial tires on it. At 60 mph I could turn the car sideways. It was dangerous to say the least. I switched over to a 275-60-15 Mickey Thompson drag radial and now the car hooks great even on the street. With stone stock suspension the car runs 11.30s. I have since invested in Cal-tracs, Ranco 9 ways and am waiting on some Calvert racing rear springs which should help out even more.
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline Cuda54
Re: Traction needed
« Reply #10 on: July 25, 2010 - 11:59:33 PM »
My 72 is the same color as yours but my hockey stripe is white with 440 in it. Right now I have ralley rims on it with 14" up front and 15" on the rear. I have a set of 15"x8" Crager SS coming for it. I have super stock springs 3.30 gears posi 2800 stall torque converter hemi band in a built 727 trans. My engine is a 440-6 with 525hp it has a lot of chrome on it too. My car was a 340 but the engine was changed before I bought it.
Re: Traction needed
« Reply #11 on: July 26, 2010 - 08:52:41 AM »
the ladderbars are less work to install than a full 4 link & yes you need a floater ,but the set up is easier & the traction is awesome , I have had good luck using Nitto drag radials from discount tire
Offline hotrod98
    • Maniac Musclecars
Re: Traction needed
« Reply #12 on: July 26, 2010 - 10:03:37 AM »
I was planning to convert one of my 71 cudas to four link but the guy at one of the dyno shops here in town said that I should go ladder bar instead. Why are they easier to set up than a four link? I thought the four links were the best way to go. I raced dragsters for 30 years so these door cars are all new to me.
1971 Cuda Drag Car
Re: Traction needed
« Reply #13 on: July 27, 2010 - 04:25:03 AM »
well a 4 link is harder to install & has about 200 possible settings , a ladder bar is a no brainer & flat out works
Offline 6PKRTSE
Re: Traction needed
« Reply #14 on: August 04, 2010 - 02:51:57 PM »
I have Cal Tracs with split mono leafs on the back of my 70 Challenger with the Doctor Diff 1" in board kit to fit 315 M/T Drag Radials. Haven't had it out to test them yet. But there are several 7 & 8 second small tire cars out there using them.
I didn't want the whole ladder bar / 4 link race car theme under my car since its still going to be a street/strip (mostly strip) car even with the twin turbo HEMI.
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, 528 Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL.
1970 Road Runner 383 4 BBL
1996 2500 RAM 488 V-10 4X4
2012 Challenger R/T Classic
