Author Topic: Hinges don't match!  (Read 1287 times)
Offline rhamson
Hinges don't match!
« on: July 23, 2010 - 09:14:11 AM »
There is a problem with closing the hood with my '72 Challenger where the hood stays up on on the right side and needs to be pressed down to make it sit right.  I know the hood should get adjusted to a certain extent but upon closer look there is a difference between the two hinges where they don't mirror each other.
The right hinge has a longer plate connecting the upper and lower arms that mesh together with teeth.  The left plate measures about 3-1/8" long while the right one measures 4".  Why the difference and is there an explanation.
Re: Hinges don't match!
« Reply #1 on: July 23, 2010 - 09:19:43 AM »
Different years had different styles, maybe yours are mixed.
See pics here  http://www.smsmopar.com/public/produits.asp?cat=1&subcat=4
Offline Slotts
« Reply #2 on: July 23, 2010 - 09:47:29 AM »
I had the same problem when I first got my car home.  :banghead:
The driver's side would only go down, even after adjusting it to its fullest extent of travel, by pushing it down into place.
Turns out someone a long time ago had changed the hinge with a Charger hinge.  :smokin:  :screwy:
Slotts
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: July 23, 2010 - 10:37:13 AM »
you also could have a later b-body mixed in. B and E look very close.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline bigblue73
« Reply #4 on: July 23, 2010 - 10:44:36 AM »
I've got an extra set of hinges that came off a '72 with the bulge hood if your interested.  They are some of the parts that I have no idea why I needed them.
Offline ShelbyDogg
« Reply #5 on: July 23, 2010 - 07:50:02 PM »
Your hinges are 2 different years. The driver's side has the teeth that mesh together and the right side is the kind without the teeth.  You still may be able to lower the passenger side though.
Chryco showed me the adjustment with my hood. You have to raise the front of the hinge UP to make the spring go over center then pull itself down.  Loosen the passenger hinge's 3 mounting bolts, have somebody stand at the front and push the hood up, while you tighten the bolts.  The hood should now close farther down.
« Last Edit: July 24, 2010 - 12:24:52 AM by ShelbyDogg »
Offline rhamson
« Reply #6 on: July 28, 2010 - 08:14:52 AM »
Thanks guys.  I believe I have a '71 left hinge and a '72 right hinge.  Thanks for the help.
