Author Topic: Low Voltage Question  (Read 884 times)
Offline MOPAR-or-NoCar73
« on: July 23, 2010 - 07:04:18 PM »
Hi
  I am running the edelbrock proflo 1 efi system on my challenger. It has been running great since I had it, but up to a few days ago I discovered that I am running a low voltage. This is a problem because the computer system requires a minimum amount of voltage to run or it shuts the car off. I tried replacing the alternator, but that did not help. I was wondering if anyone could provides any advice on other things to look at to solve this problem.
Thanks
Offline Changin Gears
Re: Low Voltage Question
« Reply #1 on: July 23, 2010 - 07:33:08 PM »
What's the voltage you are seeing?  What voltage does it shut down?
« Reply #2 on: July 23, 2010 - 08:04:18 PM »
Well, it is running around the low 11's. It shuts off in the high 10's. Changing the alternator did not increase the voltage or change it.
Offline BB73Challenger
  • 2 cars - twice the wrenching... yay?
« Reply #3 on: July 23, 2010 - 08:28:33 PM »
I'm not a wire expert but was chasing down a similar problem on my car before.
Without a constant 12 volts my ignition system would not run.
Unfortunately our cars were not blessed with great wiring to start.
Couple in decades of wear and fatigue and not to mention a backyard mechanic or two getting in the system and making changes, these systems can weaken over time.
From what I read, always make sure you have a good ground, make sure you alt is producing more than 12 volts, and begin tracking down where your voltage drop is occurring.
Possibly a junction point?
Mine was happening at the fuse box itself, with years of splicing and too much juice being pulled through too small wires.
I ultimately ended up replacing the old through a used group of wires starting all the way at the bulkhead and adding a new additional fuse box for add ons ( fans, neon, extra power point ) also leaving myself with additional extra points in case I want to run an electric fuel pump or another extra.
Hope that helps
Jeff from Cleveland, Ohio
« Reply #4 on: July 23, 2010 - 08:36:18 PM »
Possibly a bad voltage regulator not energizing the alternator or connections/ground at voltage regulator not sufficient.
Maybe Helpful
« Last Edit: July 23, 2010 - 08:38:01 PM by Bullitt- »
« Reply #5 on: July 24, 2010 - 08:21:17 AM »
Where are you measuring that voltage?
« Reply #6 on: July 27, 2010 - 11:06:17 PM »
Thanks everyone for the advice. We found the problem. The current voltage regulator was bad and had to be replaced.
