Author Topic: distributor rotation  (Read 730 times)
Offline high perf mopar
« on: July 23, 2010 - 11:03:37 PM »
if a 440 distributor turns counter clock wise,,,,should not the rotor should turn the opposite direction to intiate the mechanical advance?????not turning with the distributor. trying to figure out why my 18 degrees intial does not seem to affect things..because its turning with the dist and basicly not advanceing anything..mp billit dist #775..basicly a mallory...yh type plates.
« Last Edit: July 23, 2010 - 11:18:43 PM by 440 »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Re: distributor rotation
« Reply #1 on: July 24, 2010 - 02:50:30 AM »
the 440 dist does turn CCW , the adavance weights should centrifically move outward in that direction unless a part from a small block dist was installed under the pick up plate
