Aprilspink.........way to go on the big first place
Hemihunter..........ok lay out the info on the chally no holding back where all freinds here
ok this may change, but i swear only for the better. i'm gonna give the engine guy my 69 440 block
and tell him its gotta run on hightest when hes done, indy heads, worked if needed,hyd cam and lifters so i can work on it, bored over, mill crank, keeping SIX PACK, 727/cheetah pro street valve body,HEMI springs,pinion snubber, not sure about rear end, right now has @#$% 9inch, gears ? basically back in, way back in 82
i gave him the 396 block and said keep it under the hood cause cowl worked, but i want the tires to wrinkle and the passenger to cry.........here i go again
