Author Topic: 70 challenger motor question.  (Read 3315 times)
Offline D70challenger
« on: July 26, 2010 - 02:47:02 AM »
hey guys. well I've been searching around for a motor to rebuild for my 70 challenger, i was going to do a 440. can somebody tell me the difference here. ive seen '70 chrysler 440 motors on ebay completley assembled for about 500. but if i look for a '70 mopar 440 motor, i find Just the block for the same price, about 500. What is the difference? am i just buying the name or is the Mopar block stronger?
1970 Dodge Challenger
2005 Ford Mustang
Re: 70 challenger motor question.
« Reply #1 on: July 26, 2010 - 08:54:35 AM »
the myth is that the later blocks are weaker but this is not true ,some of the later blocks have extremely thick castings , people often look for date coded blocks for restorations and are willing to pay more to get them
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #2 on: July 26, 2010 - 09:21:52 AM »
your better off expense wise is to try to find a 440 out of a c-body or truck, seen those as cheap as 100.00. then put a set of 906 heads or what ever you want.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline hotrod98
    • Maniac Musclecars
« Reply #3 on: July 26, 2010 - 10:09:17 AM »
The HP blocks usually had steel cranks. In my opinion, a correctly turned cast crank is better than a steel crank for a street motor. Cast cranks spin smoother with less harmonics.
Also, the later blocks are more plentiful and therefore cheaper.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline 70_challenger
  • Suburban Detroit, Michigan
« Reply #4 on: July 27, 2010 - 12:22:10 AM »
Welcome to C-C.com !
There are no 'Mopar' engines or blocks from 1970 - Don't confuse yourself by how people list them on eBay.  They are all Chrysler/Dodge/Plymouth engines - same stuff.
Here is the best guide I have seen to big-block Chrysler engine blocks:  http://www.440source.com/blockinfo.htm
There is some great information on that page - Read through it, and don't let anyone tell you otherwise.  I had several people try to sell me on the myth that later blocks are thinner or weaker.  But my engine builder (Best Machine Racing) explained that their sonic testing of later blocks showed the same thickness as earlier blocks (...as CP pointed out above)
If you are not hung up on the idea of getting a 1970 date-coded block, you are best to just find a good 440 block, as mopardave suggested.  My 1970 Challenger has a 440 engine from a 1973 Dodge truck - I found the complete engine on Craigs List here in Detroit for $100.
-Tom
« Last Edit: July 27, 2010 - 12:29:31 AM by 70_challenger »
« Reply #5 on: July 27, 2010 - 04:40:53 AM »
you can build a 440 with a 440 source stroker kit for approx the same cost as machining the old parts
at least around here it works out cheaper that way but we have a typical labor rate of over $100 / hr
« Reply #6 on: July 27, 2010 - 06:14:33 AM »
thanks everybody. ya, im not not hung up on matching year. it would be cool but as long as its a 440 and its cheap then im happy. and obviously not from a marine engine or motorhome. are there any websites that you may reccomend that sell the motors? cause unfortunatley most people on ebay only do local pickup. or pay outragous shipping charges. what hp/tq number would you estimate from a rebuilt 440 motor? i was hoping roughly 400 rwhp, but i know that is probably unlikely.
2005 Ford Mustang
« Reply #7 on: July 27, 2010 - 08:00:26 AM »
I was told my 440 is out of a motorhome. They usually have next to no miles on them too!
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: July 27, 2010 - 08:40:32 AM »
77-79 C-BODY or truck/motor home are pretty easy to come by and usually cheap.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #9 on: July 27, 2010 - 09:01:54 AM »
with 512 ci & a few good parts but using stock heads I have made 398 RWHP on a mustang dyno which are really hard to get a high # on
« Reply #10 on: July 27, 2010 - 04:54:43 PM »
o really? i thought a motorhome 440 would be used and abused. if it works fine then i would be happy with that. where did you get your 512? was it just a bored out 440? i need to learn more about chrysler motors. most ford im pretty good at but im breaking the tip off my iceberg when it comes to mopar/chrysler.
2005 Ford Mustang
« Reply #11 on: July 27, 2010 - 08:03:33 PM »
A motor home 440 sometimes won't have many miles on it. It's just something they only used a couple of times a year. So the motor home sits and rots. The 512 thing is stroking the 440 to that level. So, options about stroking and bigger heads are out there if you want serious horse power.
« Reply #12 on: July 28, 2010 - 02:31:42 AM »
where do you guys find your performance parts for your old motors? like heads and such. im used to searching up 05-09 mustang parts which "5.0 Mustang and Super Fords" claimed to be the most customizable car ever made. so im used to finding an easy abundance of modifications. ive already found out that you have to really look for challenger parts, and thats just to try and get it in a stock condition, i have no idea where i would look for performance parts, i guess ebay would be my best bet? its hard going from a muscle car that has virtually anything availiable, (my mustang) to a muscle car that has hardly anything out there, (my challanger).
« Last Edit: July 28, 2010 - 02:34:53 AM by D70challenger »
2005 Ford Mustang
« Last Edit: July 28, 2010 - 08:21:11 AM by brads70 »
sleepychallenger
« Reply #14 on: July 28, 2010 - 08:58:41 AM »
there is also www.440source.com
there is a lot of conversation about them good and bad, but if you get the good, the price is not bad  :misbehaving:
