Author Topic: optimum back spacing for a 7" front wheel?  (Read 707 times)
Offline Strawdawg
    • Vortex Buicks
« on: July 27, 2010 - 11:38:04 PM »
Seems like it should be 4", but, I recall seeing 4.25" elsewhere. :)
Offline ShelbyDogg
Re: optimum back spacing for a 7" front wheel?
« Reply #1 on: July 28, 2010 - 12:45:49 PM »
4" is right. Some measure to the outside lip and get 4-1/4.  Backspacing is usually measured to the inside edge where the tire seats. Stick with 4" and you'll be fine.
Offline Strawdawg
    • Vortex Buicks
« Reply #2 on: July 29, 2010 - 10:03:45 AM »
Thanks, I appreciate it :)
Offline ShelbyDogg
« Reply #3 on: July 29, 2010 - 10:35:18 AM »
No problem.   Just be aware that alot of these aftermarket wheels have a 3-5/16" backspacing and if you put on a 235-60-15 on one of those, your tire will rub the fender around turns and  while turning into the "driveway bump"  I run the 15x7 Rallye with a 235-60 in the front and it never rubs anything. I had the 3-5/16s before and HATED them.
But I like my cars low though. The tops of my tires are inside the fender and not jacked up like some of these guys have them.
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: July 29, 2010 - 02:31:45 PM »
I am with you :)
that much offset also puts a pretty good load on the outer bearing
