Author Topic: LCA questions  (Read 998 times)
Offline AMXguy
LCA questions
« on: July 27, 2010 - 11:40:39 PM »
When you press the LCA bushing in do you press the bushing and then the pin or do you put the pin in the bushing and seat them together? and on the metal to metal pivot point between the trorsion bar hub and the LCA itself you you lube that at all? and if so with what?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: LCA questions
« Reply #1 on: July 29, 2010 - 12:39:22 PM »
I would lube the bushing so it will slide in , not sure if you can press the pin in after the bushing is in the LCA so I would press the pin in first
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: LCA questions
« Reply #2 on: July 29, 2010 - 01:15:15 PM »
When I did mine (rubber LCA bushings), I pressed in the bushing first. Then pressed the pin into the bushing. I don't think it really matters as long as both are all the way pressed in.  :2cents:
Worlds first e-body trailer.    Severna Park, Maryland
Offline shadango
Re: LCA questions
« Reply #3 on: August 05, 2010 - 08:03:18 AM »
 :iagree:  Same here.
