Author Topic: rear sway bar bushings  (Read 891 times)
Offline 30below
« on: July 29, 2010 - 12:36:11 PM »
Well,after 4 years,i finally have the Cuda on the road.Everything seems to work,except a terrible squelch sound from the rear.Think i have it figuered to the rear sway bar bushings.I put new poly ones in,and wonder if i should of used some lithium grease or something?Also does the car have to be on jackstands to remove and grease?
Re: rear sway bar bushings
« Reply #1 on: July 29, 2010 - 12:44:23 PM »
Energy Suspension a Slicone lube about the consistancy of Honey , it will not wash away with water & si what I would use in there , if you are under the car I would use jack stands , but removeing the sway bar will not cause the car or suspension to drop down
Offline 30below
« Reply #2 on: July 29, 2010 - 01:48:50 PM »
So on stands and let the suspension hang.Any need to remove or loosen the endlinks?
Offline 30below
« Reply #3 on: July 29, 2010 - 08:36:31 PM »
Got it done ,thanks
