Author Topic: 440 Engine Identification  (Read 8599 times)
Offline Skunkworks Challenger
  • Mopars forever!
« on: July 29, 2010 - 10:01:44 PM »
I'm planning to rebuild a 440 engine to install in my 70 Challenger.  The 440 was in a 78 Dodge pick-up an was cast in 1977.   The only identification stamped on the engine is on the upper ID pad.  The lower pad is totally blank. The upper pad shows:8T440 E in the top line.  The bottom line shows: 7  19 , then what looks like a poorly stamped maltese cross, then an X.  The cross and X are in approximately 3/16" size characters.
My service manual describes the cross and X as indicating under-size journals, either crank mains or rods. It further states that the cross and x , when present are in 3/8" characters and that the #3 crank counter weight will be marked showing what journals are undersized.  I measured both rod and crank journals and they are: Crank @ 2.750, all the same size and the rod journals @ 2.375, all the same. The guy that bought the engine new says that it has never been overhauled.  What is the pad telling me?  Please help!  PK
The Brewmaster
Offline BIGSHCLUNK
Re: 440 Engine Identification
« Reply #1 on: July 29, 2010 - 11:11:48 PM »
E on the pad would be 69 ....  :dunno:    Barry should have an answer to this .  :bigsmile:
« Last Edit: July 29, 2010 - 11:13:42 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
« Reply #2 on: July 29, 2010 - 11:19:09 PM »
Here's from my GTX
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Alaskan_TA
« Reply #3 on: July 29, 2010 - 11:39:55 PM »
I do not have any of that data for 1978, sorry.
  • Mopars forever!
« Reply #4 on: July 30, 2010 - 12:04:46 AM »
I think I've figured out how to post a pictue of my ID pad.  I'll try! PK
The Brewmaster
« Reply #5 on: July 30, 2010 - 12:20:18 AM »
« Reply #6 on: July 30, 2010 - 02:08:50 AM »
8T is a 78 , T for truck 440 ci & E is cast crank
 I would replace the cast crank & possibly do a 512 " stroker kit & machine the block to get your clearances & not worry about the factory build / cross & X markings
  • Mopars forever!
« Reply #7 on: July 30, 2010 - 10:55:20 AM »
Many thanks to Topcat and Chryco Psycho for your replys.  I will now move onward and upward!  PK
The Brewmaster
