Author Topic: Rear Brake locking up  (Read 1162 times)
Offline rwdeitrick
« on: August 01, 2010 - 05:25:24 PM »
I just put New wheel cylinders on my73 cuda and gravity bleed the brakes.now the rear brake locks up when you put on some pressure on the peddle anyone have this problem before  :screwy:
Offline 72cudamaan
Re: Rear Brake locking up
« Reply #1 on: August 01, 2010 - 05:45:11 PM »
First thought coming to mind is fluid on the shoes. Brake fluid or gear oil will make the shoes grab bad.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: August 01, 2010 - 06:28:08 PM »
:iagree:   check the shoes for oil or fluid
72rtchallenger
what happens in the garage
stays in the garage
Offline quapman
    • Auto-Grip on Facebook
« Reply #3 on: August 01, 2010 - 06:52:19 PM »
Yep, I'm going with leaky axle seal.
Offline Katfish
  • 70 Challenger
« Reply #4 on: August 01, 2010 - 08:26:34 PM »
Interesting, seems like grease / fluid would make the brakes have less grip?
My rears lock up before the fronts under extreme / panic type stops.
Never thought of checking the rear pads, what's the remedy, hit them with some sandpaper?
  • 72 to 70 clone
    • cardomain
« Reply #5 on: August 01, 2010 - 08:47:16 PM »
you can try that and clean the drums also,,has to be clean of oils
72rtchallenger
stays in the garage
« Reply #6 on: August 02, 2010 - 11:20:45 AM »
you need to soak the pads with brake clean , if the shoes are badly saturated they will need to be replaced
Offline rwdeitrick
« Reply #7 on: August 02, 2010 - 01:01:23 PM »
thanks guys i guess i have a small weekend project comming up  :working:
