Author Topic: lightweight master cylinder swap  (Read 1375 times)
Offline black71
  • eph 6:12
« on: August 02, 2010 - 12:15:57 AM »
k so i tried mocking up my lightweight master cylinder/adapter and could not get the belcrank to line up...i am converting from power discs......am i missing something?
Re: lightweight master cylinder swap
« Reply #1 on: August 02, 2010 - 11:21:28 AM »
what parts are you using , any pictures ?
« Reply #2 on: August 02, 2010 - 06:25:55 PM »
I used the DR Diff kit off E-bay and I'm happy with it! Works great. Manual brakes do take some getting used to though....
Isn't the rod different for manual brakes as compared to Power brakes? (on the pedal)
Offline black71
  • eph 6:12
« Reply #3 on: August 03, 2010 - 12:45:57 AM »
sorry i'll try and get pics...its a ARE adapter with a manual backing plate and the power pedals
Offline black71
  • eph 6:12
« Reply #4 on: August 03, 2010 - 12:49:30 AM »
oh and an adjustable brake pushrod from summit (stainless steel brakes)...thinkin i shoulda gone with the mopar performance  :banghead:
« Reply #5 on: August 03, 2010 - 09:09:44 AM »
You don't use the bellcrank, only a pushrod direct from the pedal to the cylinder. Is your adjustable rod to long/short or something?
Offline black71
  • eph 6:12
« Reply #6 on: August 08, 2010 - 01:42:06 AM »
first pic shows power master bracket and you can see how high the hole is
3 is adapter and manual bracket
4 shows how low they mount
5 shows what the manual hole lines up with
bottom circle on 6 shows where it lines up and top circle is where the hole lines up with the power bracket
Offline mopar12372
    • mopartech
« Reply #7 on: August 08, 2010 - 02:14:19 AM »
i believe the steel plate needs to be removed use the 4 bolt holes and mount it.
RESTO PICTURES
« Reply #8 on: August 08, 2010 - 01:55:02 PM »
I took a picture of what I have? Hope it helps? Couldn't get a good picture from under the dash.... In the e-bay listing it said something about the M/C piston being machined for a manual push rod..?
Offline mopar12372
    • mopartech
« Reply #9 on: August 08, 2010 - 02:25:11 PM »
heres my picture with the mancini racing mounting plate and 15/8 master from mopar with adjustible push rod .
all bolted up with minimal problems only adjusted push rod. hope  this helps
RESTO PICTURES
Offline 422STROKER
  • Member Since 6/3/06
« Reply #10 on: August 08, 2010 - 05:50:30 PM »
Here is mine with the plate.
Tom
Tom
