Author Topic: BB Mopar Road Race pan  (Read 3287 times)
Offline 73restomod
« on: August 02, 2010 - 11:43:28 AM »
Just bought a Milodaon 51380 road race pan, only 5.5 inches deep, holds 7 qts., dual kickouts, lots of trap doors to keep oil where it belongs. Really nice piece, anyone ever use one, or have any known issues with it, ie. header clearence, draglink etc. ?? :working:
Also anyone know of a program that i can download to shrink down/convert photos?? was gonna post pics with this thread but hey are all to large.
« Last Edit: August 02, 2010 - 11:48:12 AM by 73restomod »
Re: BB Mopar Road Race pan
« Reply #1 on: August 02, 2010 - 04:14:08 PM »
 :popcorn:  I'd like to see pictures of that! Sounds nice!
Offline drewcrane
« Reply #3 on: August 02, 2010 - 04:17:07 PM »
I hope you got the right pick up for it ,cause it is different ;)
Offline 73restomod
« Reply #4 on: August 03, 2010 - 11:09:40 AM »
Thank you for the pics and the site info, yes it is that pan! I also got the recommended pickup for it from milodon as well, so I should be good to go. I am runing 2in primaries on the motor so i figured it would be pretty tight even with a factory pan.  :2thumbs:
Offline autoxcuda
    • Spring Fling
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline drewcrane
« Reply #6 on: August 03, 2010 - 03:51:44 PM »
Does it have deacceleration doors in each side pod in addition to the 3 in the center? I thought they had actually 5 hinged doors.
yea your right i forgot about those other doors, here is another pic
that shows the outside hinged doors
Offline arcticmopar
  • Yukon Canada
« Reply #7 on: August 03, 2010 - 04:35:15 PM »
Thanks for the pics...first time I,ve seen a photo of it! :clapping: Does it take a stock dipstick and if so whats the tube welded to the kick-out for?
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline drewcrane
« Reply #8 on: August 03, 2010 - 05:00:22 PM »
yes it does take the stock dip stick, and the fitting on one side is for oil pressure, or temp,
but with headers there is no room for anything like that on my car so it has a threaded plug ;)
« Reply #9 on: August 03, 2010 - 09:16:36 PM »
What brand of headers are you running? Got any pictures showing how close it is?
Offline drewcrane
« Reply #10 on: August 04, 2010 - 07:55:26 AM »
Im running TTi headers,i will see if i can get a pic today :naughty:
« Reply #11 on: August 04, 2010 - 08:32:30 AM »
I wonder if I could cut the sump off that and weld up to a small block pan?   :clueless:
Offline IMNCARN82
  • LeDZeP
« Reply #12 on: August 04, 2010 - 09:13:40 AM »
My Milodon A engine pan fits terrible. About to chuck it. It's completely off at the front/back where the seals go.  Bet you could do it HP...    hey, what about those pans you were talkin' about having made? Not much response?    I'm about to try moroso.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #13 on: August 04, 2010 - 02:05:55 PM »
There are probably 12-15 people interested in one, which would get the price down around $400, but Canton won't design it, I have to. Sooo, until I get time to actually crawl around under a car and take measurements and mock up dimensions, nothing is happening.
Offline ntstlgl1970
  • T a c o c a t
« Reply #14 on: August 04, 2010 - 03:00:36 PM »
You can buy a u weld it road race sump kit from moroso for way less than what this pan ($350 without the pickup) costs. HP -send me a pm -
I have this pan on my car, and the only negatives are that the drain plug hits the centerlink at full lock (stock manual steering/stock length pitman and idler arms) and I had to take a 45 degree angle cut to the bottom of one of the k member motor mount brackets to drop the engine in from the top with the A/T in the car. Also, if you are using the milodon windage tray, make sure to dummy up the tray/pan and dipstick tube to make sure your dipstick clears the tray- mine took some massaging to make it work.
« Last Edit: August 04, 2010 - 03:10:46 PM by ntstlgl1970 »
