Author Topic: trans mount issues  (Read 981 times)
Offline CUDA JAS
  • vroooooom!
trans mount issues
« on: August 02, 2010 - 01:19:57 PM »
Working on replacing my trans mount...but seem to have a problem.
The mount on the left is the mount that I pulled off the car and the one on the right is the replacement from Rock Auto.
As you can see there is a difference between the two..the one on the car was on there when I bought the car and has obviously been modified.
Is the one on the left the correct part???
Thanks,
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline BB73Challenger
Re: trans mount issues
« Reply #1 on: August 02, 2010 - 04:07:28 PM »
The one on the right looks like the one from my car....
but I suspect you gussed they woul have sent you the right one when you seen your "modified" original.
With that being said, I don't have much more to offer  :sadwavey:
More modding to be done to your new?
Maybe someone else will have a better idea?
Is your trans. not origianl to the car?
Jeff from Cleveland, Ohio
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: August 02, 2010 - 04:37:14 PM »
Yeah, I hoped they would have sent me the right one.
No the trans is not origional to the car..its a 727 out of an 80 new yorker...but I understand that the trans are all the same.
Jason
74 'cuda 360/727
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: August 02, 2010 - 06:39:34 PM »
Looks like the same thing in my car, try putting it in, your old one is pretty deteriorated and looks way different in the rubber area.  But the metal besides a bit of cutting looks similar.
Tom
Tom
Offline Changin Gears
« Reply #4 on: August 02, 2010 - 06:55:26 PM »
Remember when you install it that those slotted holes are there for tolerance stack-up.  Keep those bolts loose.  Install the cross member and the through bolt, then tighten thse bolts going up to the trans.
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: August 04, 2010 - 10:23:38 PM »
Thanks guys.
I sorted out an engine mount issue and the trans mount fit.
Jason
74 'cuda 360/727
