Author Topic: Totally Frustrated!  (Read 6873 times)
Offline 72cudamaan
Re: Totally Frustrated!
« Reply #30 on: August 06, 2010 - 11:11:51 PM »
What are u using a gasket for with all that silicone? seriously, a very thin film to hold the gasket in place is all u need. Or better yet, a coupla dabs of weatherstrip adhesive  will work wonderfully.  All IMO of course.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Strawdawg
    • Vortex Buicks
« Reply #31 on: August 07, 2010 - 10:57:32 AM »
and don't use silicone around the intake ports..that is a no-no
« Reply #32 on: August 07, 2010 - 11:02:41 AM »
Try 440-A gasgacinch instead......will still need silicone on the ends
http://www.oreillyauto.com/site/c/detail/GAS0/440A.oap?pt=N1759&ppt=00000
Offline wD-Boston
« Reply #33 on: August 07, 2010 - 11:26:06 AM »
Well I guess thats what happens when I let others do it for me.....lesson learned.
I got the intake and heads cleaned up nice and I'm ready to install the new gaskets. I agree with Bullitt- that the ends do need some rtv, like what 72cudamaan said just a think coat to keep it in place and add a lil extra seal around the water jacket.
The only thing I'm not clear on is the heat block off plate. Which side of the gasket should I place it? My guess would be on the cylinder head side. It also appears to be a tad long. Should I trim it down or is it ok just to go keep it even with the bottom on the cylinder head?
BTW can anyone show me the torque sequence of the intake, my factory service manual only shows it for the Hemi.
« Last Edit: August 07, 2010 - 11:30:03 AM by wD-Boston »
wD-Boston
"I judge the intelligence of others on how often they agree with my opinions."
« Reply #34 on: August 09, 2010 - 04:22:56 AM »
I would put the block off in place as you have it in the picture
torque from the center out for the intake
Offline mopar12372
    • mopartech
« Reply #35 on: August 09, 2010 - 01:07:11 PM »
 :iagree: in a criss cross pattern.
RESTO PICTURES
Offline wD-Boston
« Reply #36 on: August 09, 2010 - 06:22:18 PM »
Yep I started in the middle of the intake and worked my way outwards. Fired right up and no vacuum leaks. I fattened up the fuel mixture along with adding some wet wetter with the coolant and the engine didn't break 165F   :bananasmi
Now to pop the Carter AVS back on.
wD-Boston
« Reply #37 on: August 09, 2010 - 07:50:50 PM »
 :woo:
Offline 72cudamaan
« Reply #38 on: August 09, 2010 - 08:16:00 PM »
 :cheers:   I love it when a plan comes together!    And your pic of mounting the new gasket is awesome. Wish the first guy lined things up that nicely.
Offline wD-Boston
« Reply #39 on: August 10, 2010 - 05:46:51 PM »
I really would like to thank everyone for there input. I really learned a lot.  :2thumbs:
wD-Boston
