The issues I'm having started about 12 weeks ago after taking the car out of winter storage. I replaced the Carter AVS that I had on the engine for the past 19 years for a eddy 650 cfm ( I can just see Chrycos response now ) because a good buddy of mine finally convinced me. Reason was the car would stall periodically so we figured it was time for a new carb. More on this later
It worked fine until I let a family member who is a "mechanic" try to tweak the carb. Since then it's the performance of the car has slowly gone down hill.
Slowly but surely the performance eroded to the point that it just kept stalling. Was able to fire it up and keep an idle but once it went into gear it would stall.
Tried different timing settings but with the same result.
So going on my buddies advice given the symptoms it sounded like a jumped timing chain. Crank and cam markers lined up perfectly and #1 piston is at TDC.
I checked the perimeter of the intake and found a small vacuum leak so I replaced the intake gaskets. Get everything back together still same symptoms but now the engine is running hot
I drive it down to my buddies so he could see it for himself and come to realise that the torque converter is locked up.
Funny because I had it changed out last August because the torque converter bolts were backing out and hitting the block. So I gave it to the family member to replace as a favor cause he just opened up his own shop.
So I replaced it with a Hughes 2000-2200 stall,set the timing and the carb and now runs great......
Driving home, which I have to use the highway I noticed the temp keeps climbing....not good
I get off the highway and having a hard time keeping it at idle, stalls out a few times on the way.
I flushed the radiator, installed a new water pump,160 t-stat,plugs,wires,coil and fuel filter.
When the car is cold it runs fine but after it warms ups after about 20-30 minutes is when it starts having problems....runs hot and engine won't hold an idle.
I did notice when I was burping the engine of air that I pulled out a sliver of black rtv from the radiator, should I remove the intake manifold and check for blockage? The car never ran this hot before. I believe this is whats causing it to run like crap.
Sorry for such a long post but I just want to show the time line of events to today.
Engine is a 340 w/ slight cam ( sorry don't have the specs) auto and mopar electronic conversion
I'm really at my wits end and can really use some help
wD-Boston
