Author Topic: 1970 charger vin  (Read 1120 times)
Offline JasonTx
1970 charger vin
« on: August 04, 2010 - 01:36:19 AM »
How do i check to see if a 1970 charger is matching numbers? I ran the Vin and it does say it is a RT 440. But i am trying to see if its the original block (motor) so where do i look?
Thanks
Offline CarelianCuda
    • http://bot.fi/3gu
Re: 1970 charger vin
« Reply #1 on: August 04, 2010 - 04:05:16 AM »
http://www.mymopar.com/enginecastnumb.htm
Quote
on 1968 and later engines the numbers stamped on the lower rail of the engines right (passenger) side match the last 8 digits of the cars vehicle identification number
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Alaskan_TA
« Reply #2 on: August 04, 2010 - 03:10:42 PM »
Passenger side of the block, down low. Passenger side of the transmission.
For the body, radiator support & driver's side trunk rail, dash VIN, fender tag & Mylar door sticker.
You can also check with Chris at http://www.1970chargerregistry.com/ to see if he knows anything about it.
