Author Topic: Installing Engine & Trans  (Read 4730 times)
Offline daveh
« on: August 04, 2010 - 04:43:41 PM »
Ok guys everyone has convinced me to remove the K-member and install the engine and trans from the bottom.  Especially since I'm installing a TKO-600 in the 71 Challenger.
Anyway being a chevy guy for the past 25 years and never working on a Mopar I really don't know what is the best way to proceed.  I removed the engine and trans and I'm getting ready to paint the engine bay after the K-member is out.
My question:  What is the best procedure to go about removing the K-member, torsion bars and upper and lower ball joints, etc?  I just don't want to have something go flying, like a chevy coil spring could if you don't know what you're doing.
If someone has step by step procedures on removal and installation (torque specs) with pictures I would really appreciate it.
One more question: Can the engine with the headers attached be installed from the bottom with the steering components installed or do I install the steering components after the engine is installed?  Thanks
Re: Installing Engine & Trans
« Reply #1 on: August 05, 2010 - 01:36:23 AM »
take the presuure off the torsion bars by undoing the bolt in the lower control arm , remove the nut from the front of the lower control arm pivot & the clip at the rear of the T bar  & pry both back ,the T bar will slide out , I remove the brake rotor & remove the 2 bolts holding the lower ball joint onto the spindle . all the steering gear can remain attached to the K frame , I use a snow mobile pad as caters to move the kframe with the engine & trans as one unit to roll it under the car
« Reply #2 on: August 05, 2010 - 07:58:03 AM »
There should be a wire clip at the backside of each torsion bar in the cross-member that needs to be removed before the bars can slide back.
« Reply #3 on: August 08, 2010 - 09:53:08 PM »
If you have a 4 post car lift like a backyard buddy, will that work for lowering the car down to the k-member?
Offline hotrod98
    • Maniac Musclecars
« Reply #4 on: August 09, 2010 - 06:16:50 PM »
Here's how we do it.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline daveh
« Reply #5 on: September 22, 2010 - 02:32:28 PM »
Hotrod98,
Thats a great pic of the engine cradle.  It looks so good I was wondering if you would be interested in selling me one?  I appreciate it.  Thanks
Offline ragtopdodge
« Reply #6 on: September 22, 2010 - 05:42:30 PM »
Hotrod98,
http://www.uscartool.com/kframestand/index.html
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline mopar12372
    • mopartech
« Reply #7 on: September 23, 2010 - 01:46:46 AM »
good idea if you have the right equipment , if your in your garage and only have jackstands and a jack or car ramps, i say put it in through the top but thats just me . eather way it all works out in the end.,
RESTO PICTURES
Offline daveh
« Reply #8 on: September 23, 2010 - 10:09:39 AM »
I can weld something like that up.  Just have to go buy some 2" square tubing, the casters I already have.  I just needed a good picture to go by.  I was planning on installing it through the top of the bay but you can't with the trans, headers and accessories installed which I want to do.  It's just easier that way and with everything attached you can't go in from the top.  I'm also converting to a Kessler 5 speed and this way I'm not laying under the car trying to figure it all out.  Thanks everyone.
Offline the_engineers
« Reply #9 on: September 23, 2010 - 10:25:12 AM »
Look through Dodgeboys build thread.  He used a cherry picker to lift the front of the car and then roll the engine/trans assembly under.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline daveh
« Reply #10 on: September 23, 2010 - 10:50:50 AM »
I plan on doing something similar.  I have a chain hoist attached to a steel I beam in the garage and will use that to lift it.  Been doing it for years pulling engines.  The best part is that I put rollers on it so it will have a little give when I need it too.  Thanks again
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #11 on: September 23, 2010 - 02:33:54 PM »
 :dunno:  Good luck with that, can't remember just how long ago thos pic were post but for whatever reason this site seems to delete pics within post within a rather short time period. Theat sort of makes our resto threads usless to reference to have actual visuals to go by. :clueless:  But I do remember some great shots of his resto.  :2thumbs:
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline vinb
« Reply #12 on: September 23, 2010 - 08:44:10 PM »
Leave the upper control arms on , just disconnect from the upper ball joint or you will have to do the wheel alignment over...
