rocker arm/rocker shaft play, ´70 318
Author Topic: rocker arm/rocker shaft play, ´70 318  (Read 721 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: August 04, 2010 - 11:16:10 PM »
HI Guys.
How much play should there be between rockers and the shaft "up/down" I have a sound there sounds like rocker play. checket the lifters, pushrods and camshaft. But I have some play en the shaft, could it be that sound i looking for.
Thanks Again guys  :cheers:
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Re: rocker arm/rocker shaft play, ´70 318
« Reply #1 on: August 05, 2010 - 01:58:08 AM »
with a hydraulic cam there should be no vertical play
 pull the rockers & use a magnet to remove the lifter & check the bottom of the lifter to be sure the cam has not failed
Offline Danishmopar
« Reply #2 on: August 05, 2010 - 06:30:09 AM »
Thanks Chryco.
Had the lifters up yesterday and checket the cam and lifters, pushrods. Was very fine. But i have 1,5 mm vertical play between the rockers and shaft, to much I believe.
Thanks guys
« Last Edit: August 05, 2010 - 07:36:59 AM by Danishmopar »
