Well, i got the fenders on,still need to do final alignment . I really messed them up though. The paint came out SO freakin good, But i ran the clear heavy on the top of not ONE but BOTH fenders. I had no room to move around and got hung up on my air line.
Long story short,i tried wet sanding the runs out, but im scared im going to break through into the base coat. I've also heard that once you create a run,even if you sand it out you will always see it. Is it possible to sand it down spray base coat in just that area and then use a spot panel clear to blend?
My other option that i thought of ,was to spray the tops of the fenders and the tops of the doors with a textured black paint. Kind of like an AAR cuda. Not sure how "just " the fenders would look black without doing the hood though?
http://www.cartype.com/pics/1196/full/aar-cuda_hood1.jpg
