Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
how to gear adjustment 904 trans
« previous
next »
Print
Pages: [
1
Author
Topic: how to gear adjustment 904 trans (Read 2351 times)
Talkwrench
Perth, Western Australia
Jr. Member
on:
August 05, 2010 - 09:06:26 AM »
Anyone got any tips on how to correctly adjust the gear shift on a 904, will this go in conjuction with the kick down, cant do one without the other? I cant get 1st gear manually, all else ok .
Logged
"Came too close to dying to stop living now!"
tactransman
Sr. Resident
1973 Challenger- Member here since April 14, 2006
Re: how to gear adjustment 904 trans
Reply #1 on:
August 05, 2010 - 10:52:34 AM »
Check for "slop" in the shifter linkage (worn plastic bushings,worn steel,loose bolts etc) If that is all good,you may need to cut a section out of the shifter lever coming off the trans to make it shorter and have a quicker "ratio"
Logged
Terry
-tactransman
Union, Mo.
Talkwrench
Jr. Member
Reply #2 on:
August 05, 2010 - 07:18:04 PM »
OK i'll take a look at that.. so there is no nut and bolt adjustment??
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #3 on:
August 05, 2010 - 07:47:18 PM »
There is an adjustment on the rod that connects at the pivot to the lever in the tranny but it's all relative, if you make 1st work you may not be able to go into park, give it a try but I imagine Terry has been there many times & worn parts will be the culprit.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Bullitt-
Permanent Resident
Reply #4 on:
August 05, 2010 - 07:50:30 PM »
adjustment at swivel
Logged
Huntsville, AL
Talkwrench
Jr. Member
Reply #5 on:
August 08, 2010 - 08:46:55 AM »
Checked the linkages, not to bad, some new split pins. Simple adjustment at the pivot, selected first gear tightened the adjuster there, bingo! perfect..
Logged
tactransman
Sr. Resident
Reply #6 on:
August 08, 2010 - 09:16:01 AM »
Logged
Terry
-tactransman
Union, Mo.
Tonefiend
Full Member
'70 Challenger
Reply #7 on:
August 19, 2010 - 04:36:53 AM »
My column shift linkage is all sloppy and worn out. Also my kickdown does not work. Does anyone sell a kit with all the hardware to go in and do the tighten up on all the connections?
Also, I used to put shift kits in my cars to firm up the shifting. I would like to do this to my 904 when I change the fluid and filter. What do you guys recommend? I think I used to use the B&M kit.
Logged
tactransman
Sr. Resident
Reply #8 on:
August 19, 2010 - 09:30:44 AM »
You need the kick down working correctly or it will burn up the trans! Don't drive it till you get it straightened out.
Here is some more info:
http://www.cuda-challenger.com/cc/index.php?topic=20391.0
Logged
Terry
-tactransman
Union, Mo.
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
