Author Topic: 143 tooth flywheel  (Read 892 times)
Offline Zack Mckellips
143 tooth flywheel
« on: August 06, 2010 - 10:37:29 PM »
So I just bought a 143 tooth billit hays flywheel, #11-430, used and cheap, I'm trying to change my 360 auto to a 4 speed, I have a a833 with small bearing retainer, and my 360 is internal balanced, does anyone know if this 143 flywheel will work?  It has a clutch and pressure plate with it, I got it cheap from a guy that was moving and it looks great, I do not have a bellhousing yet, is there a way to make this work, if so what do I need, or should I sell this and get a 130 tooth?
its an E-body if it makes a difference
« Last Edit: August 06, 2010 - 10:39:35 PM by 73_rally »
Offline Changin Gears
Re: 143 tooth flywheel
« Reply #1 on: August 07, 2010 - 08:10:45 AM »
The bellhousing will be the problem.  Chrylser never used the 143 tooth flywheel with a small block in a car.  They did in the trucks but, I don't think those bellhousing ever had the a833 bolt pattern.  All the aftermarket small block blowproof bellhousings I have seen are for the 130 tooth only.
« Reply #2 on: August 07, 2010 - 09:41:40 AM »
I read somewhere, that if you use a cast sb bellhousing that there is room, but I don't know if its for a a833?  :feedback: :feedback: :feedback: :feedback:
« Reply #3 on: August 07, 2010 - 10:16:33 AM »
The starter need to be located in the correct position, It's different for the 143.
« Reply #4 on: August 09, 2010 - 04:20:24 AM »
check with Brewers to see fi there is a solution
