Author Topic: Will a '77 360 harmonic balancer work on a '70 318?  (Read 1382 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« on: August 08, 2010 - 04:31:38 AM »
The title says it all.   Will a '77 360 harmonic balancer work on a '70 318?
Will a set of '77 360 heads work as well?
Offline UKcuda
  • Tell them I'm on my way
Re: Will a '77 360 harmonic balancer work on a '70 318?
« Reply #1 on: August 08, 2010 - 04:49:18 AM »
No, they are different balance (I think the 'teen is internal balance).
Yes but your CR will be hopelessly low.
'72 'cuda
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2 on: August 08, 2010 - 04:58:07 AM »
Damn too bad found one on CL for almost free.  Thanks!
I'll keep saving for the 340 build...
Offline UKcuda
« Reply #3 on: August 08, 2010 - 05:38:08 AM »
If you are collecting 340 parts anyway then I think the early 340 balancer will work on a 318, the '70/'71 340s had forged crank with internal balance.
Also I think a 318 magnum one will work, but you'd need to get the non-serpentine one to match the LA ancillaries.  Some of the 360 Magnums in trucks had non serpentine ones (like on a 360 crate motor) but I'm not sure about the 318s.
I've got a 318 balancer here under my bench but I guess that's not much good 2,000 miles away !
If you find an "unknown" one just look whether it is the same all the way round, if so it will be the correct (neutral) balance, ie. one without any sections cut out.
'72 'cuda
Offline Cooter
    • christinecarclub.com
« Reply #4 on: August 08, 2010 - 08:10:47 AM »
All the Later model 1992 up Magnum engines are of diffferent balance....Flywheels and balancers will not work...
Offline acudanut
« Reply #5 on: August 08, 2010 - 10:03:08 AM »
 Great info cooter, but he was talking about a 70 and an 77.
Offline UKcuda
« Reply #6 on: August 08, 2010 - 02:46:44 PM »
Sorry I disagree - the magnum 318 is internal balance, same as the LA 318s
The 360 magnums are external balance but different balance from the LA 360.
I have LA 360, Magnum 360, LA 318 and Magnum 318s all in my garage, so I can promise you this is right.
'72 'cuda
Offline UKcuda
« Reply #7 on: August 08, 2010 - 02:48:22 PM »
I was talking about the Magnum, cooter was responding to me (inaccurately as it happens).
'72 'cuda
