Author Topic: Anyone Ever Replace Saginaw Steering Pump Shaft Seal ?  (Read 1789 times)
« on: August 08, 2010 - 10:57:25 AM »
  Our 2nd Dakota has a leaking PS pump & I believe the shaft seal is the problem. On the 1st one I got a re-manufactured unit but I'm thinking of trying to replace just the seal maybe even in the truck.  I checked & the same seal is specified for my '73 so this must be a very common pump.
   Anyone ever do this?   Any advice?
 Thanks
Wade
Re: Anyone Ever Replace Saginaw Steering Pump Shaft Seal ?
« Reply #1 on: August 08, 2010 - 11:26:56 AM »
You'll need to get the shaft out. If you do that, you might as well re build it. I re built my Federal. Took about an hour. Albeit, if I did it again, would take less time doing it again.
Here's a re build from the Corvette forum. Chevy or Mopar, a saginaw is a saginaw.
http://www.corvette-restoration.com/restoration/motor_and_transmission/060813_power_steering_pump_rebuild.htm
Offline BIGSHCLUNK
« Reply #2 on: August 08, 2010 - 11:33:10 AM »
Good link Mike, but I'd probly take the lazy mans way out and just hang a different pump.  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: August 08, 2010 - 11:36:00 AM »
Another choice is Pick n Pull. Only 5 miles away from me.  :grinyes:
Offline BIGSHCLUNK
« Reply #4 on: August 08, 2010 - 11:47:17 AM »
Support your local auto recycler!!  :cooldancing:  :cooldancing:  :cooldancing:
not that I have an opinion on that...  :roflsmiley:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #5 on: August 08, 2010 - 12:11:50 PM »
Thanks for the great link TC.....
This is the seal....In my hard-headed way I'm thinking there must be a way to do this w/o dis-assembly.
