Author Topic: removing chrome moldings on qtr panel / trunk  (Read 1144 times)
Offline 74MOPAR
« on: October 29, 2004 - 10:46:28 AM »
 How to remove the chrome moldings [ the inverted L shaped ones ] on the trunk section of a Barracuda ?
  I haven't really looked inside but one of the clips is busted and my molding is loose at the top. I don't want to lose it while going down the freeway from air drag. :(
  Figure I'd ask here before I attempt to remove it, maybe there is a trick to it, don't need to bend it...  Thanks.
74 'Cuda + 73 Charger Rally + $$ + assembly= Noble M400
 03 Ram Hemi 4x4
 78 Aspen Super Coupe
Re: removing chrome moldings on qtr panel / trunk
« Reply #1 on: October 29, 2004 - 05:54:57 PM »
I'm figuring that Cuda's are like Challengers. If you open up the trunk and look inside at those buggers, you'll see three 3/8 inch nuts attatched to those clips. It is possible for a clip to come out from underneath the trim, and seem useless. Maybe that's all that happened to you ??? This isn't a tricky situation by any means.
