340 vs 440
Author Topic: 340 vs 440  (Read 38059 times)
Offline 67vertman
  • Member since 9-23-2005
340 vs 440
« on: August 08, 2010 - 09:17:11 PM »
I have owned both, big blocks and small blocks, and there is a lot to say for both engines. I am still on the fence on which way to go BB or SB.
So, the question is, for a weekend driver and occasional car show, and mostly fun to drive car, which motor would you choose?  All other items will be the same wither it’s a BB/SB - 4 sp, 355 gears, power disk brakes, A/C.
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: 340 vs 440
« Reply #1 on: August 08, 2010 - 09:39:04 PM »
both engines being great is hard decision,,but as a good built 340 can preform and hold its own against the 440,and is a force of its own ,I would go with the 340 as it is better on the highway mileage with gas so high,and it is  lighter in weight . just my  :2cents:
and when you out do a bb on the track you have bragging rights   :stirpot:   :poopoke:
72rtchallenger
what happens in the garage
stays in the garage
Offline TreeFrog
    • TreeFrog
Re: 340 vs 440
« Reply #2 on: August 08, 2010 - 09:41:36 PM »
It truly is a hard call, and a personal preference.
My 72 has a 360, and my wife's 73 has a 340.
If I had to start from scratch .... I would say
340 automatic or 440 standard
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Re: 340 vs 440
« Reply #3 on: August 08, 2010 - 09:49:32 PM »
340 or 440, Both answers are correct.
Just like Chocolate or Vanilla Ice Cream!
Alaskan_TA
Re: 340 vs 440
« Reply #4 on: August 08, 2010 - 09:49:56 PM »
I have had both & respect both, & I have been beaten 440 cars with a 340.
Priceless.  :bigsmile:
Offline hotrod98
    • Maniac Musclecars
Re: 340 vs 440
« Reply #5 on: August 09, 2010 - 01:34:35 AM »
I have both. I really enjoyed my 71 Cuda with a 340, 4-speed that I just sold last year. It was a blast to drive and was much more nimble with the smaller motor. Got a lot better fuel mileage as well. Remember, these cars are 40 years old and the metal is a little fatigued. You will get much less cowl shake with the lighter engine and much less roll in the corners.
I have two 71 drag cars, one with a well built aluminum headed 360 and one with a relatively mild 440. The mild 440 will blow the 360 away. For all out brute power there is no replacement for displacement.
The best small block car that we own is my wife's 73 Cuda with a 5.9 FI and A518 od trans. Cruise, a/c and 29 mpg. A new 5.7  or 6.1 would be even better.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Re: 340 vs 440
« Reply #6 on: August 09, 2010 - 09:45:30 AM »
Get a new siamesed 340 block with a 4.125 stroker crank and you can have 440 cubic inches in a 340 package. Then you could say you have both.
Offline cudadave72
  • you motorboatin sob!!!
Re: 340 vs 440
« Reply #7 on: August 09, 2010 - 10:38:07 AM »
Its all going to depend on what you are wanting out of your car. Apples to apples a stock 440 is going to out perform a stock 340 in a straight line contest. On the flip side the 340 will offer better handling due to lighter weight. As said before there is no replacement for cubic displacement, however a well built small block can offer up big block performance but that will cost $ and you will lose some driveablity. Everyone on here knows by now that I love my smallblock but you have to be realistic in your goals. :2thumbs:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline 67vertman
Re: 340 vs 440
« Reply #8 on: August 09, 2010 - 10:39:32 AM »
HP2, i have been thinking about that myself.
Offline 67vertman
Re: 340 vs 440
« Reply #9 on: August 09, 2010 - 11:07:31 AM »
HotRod98, you bring up some good points.  I want to enjoy my ride and although fuel mileage doesn’t bother me, overall drivability does.  Either way I go, all other components will remain the same, frame stiffeners suspension, gears and such are going on, no matter what motor goes in.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: 340 vs 440
« Reply #10 on: August 09, 2010 - 11:15:08 AM »
Driver/cruiser...  Why not consider a stock stroke 383 or 400?  Stealth heads and you will be light as a SB and look like a stock B engine.
Don
Member Since January 14, 2002
Offline Speedygjr
Re: 340 vs 440
« Reply #11 on: August 09, 2010 - 11:36:53 AM »
There's no substitute for cubic inches.
Offline Road_Runner
Re: 340 vs 440
« Reply #12 on: August 09, 2010 - 11:40:12 AM »
Well since you asked what we would do, I'd say 340 since I specifically bought my 73 Barracuda to be more of a pony car than a muscle car.  That way I'll end up with one of each because I already had a BB Roadrunner that I'm either going to stroke the 383 to 438 (almost a 440) or go with a stroker hemi.  I'm leaning heavily towards the stroked 383 but still haven't made my mind up completely.  Biggest thiing to me is whether you want absolute quickest straight line acceleration or might want to take it around some twisties at some point.  A 440 in the nose isn't going to lend itself to cornering and on/off acceleration like my Roadrunners can be downright dangerous if you punch it mid corner (trust me I know).
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline HemiOrange70
Re: 340 vs 440
« Reply #13 on: August 09, 2010 - 11:44:27 AM »
340
If your car is set up for a small block, then less money and frustratiion to convert and a 340 is a good performer, lighter and fast. Big blocks you compromise handling for HP
Offline 426HEMI
Re: 340 vs 440
« Reply #14 on: August 09, 2010 - 11:46:05 AM »
So you want our opinion.  As all know on here I prefer the small block for all around.  I have owned my share of big blocks and some that were very stong.  I like the small blocks because of the handling.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
