General rule of thumb is 500# for small block, 600# for big block, 700# for a Hemi. They can be a bit higher or lower depending on accessories.
So, stick on aluminum heads, aluminum water pump, lighten some stuff up and remove some accessories and you can get a big block in to unaltered small block weight territory. However, apply those same changes to a small block and you can get in to featherweight territory.
But, in power per dollar, a big block is still hard to beat. You can get small blocks to absurb for street use power levels, but it does take more $$$ to get them there.
Personally, for simple wow power, a Nascar P engine would take it over small block, big block, or Hemi in my book.
