Thanks for your input, it is so good to speak to another mopar freak, I'm on my own here. Have done the whole inspection thing, but the noise doesn't happen when shes jacked up, which is making it so diffcult to find, hence my torsion bar suspicion. Do you have an idea of the correct spacing between the the the strut washers, bcause the bushes are still looking good. I think maybe the front to back movement of the strut rod is causing movement at the lower control arm/torsion bar socket area - I can feel the noise at my feet, I assume from the rear torsion bar mounting? Am I making sense? Ball joints, bearings, brakes, tie rods are all new.
