71 Challenger Convertible Resto Help
Author Topic: 71 Challenger Convertible Resto Help  (Read 3558 times)
Offline daveh
« on: August 09, 2010 - 10:39:23 AM »
Hi Guys,
I am getting ready to remove the K-member and want to construct something with wheels to put under the front so I can move it around.  I' guessing I would attach it to the bumper bolt holes somehow.  I only need it for the front the real axle is still in and I have regular dollies under them.
What I am looking for is pictures of creative ideas that I can use.  I appreciate it very much.
Offline sprecks
Re: 71 Challenger Convertible Resto Help
« Reply #1 on: August 09, 2010 - 01:04:59 PM »
Are the doors on the car? The reason I ask is if not, be sure to put a brace from the hinge to the door striker. This will keep the body flex down to a minimum. Attaching the dollie wheels where the bumper brackets attach will work fine. This is where I attached the rotisserie when I did my car. But don't do it with the doors removed without the brace. If the doors are on the car, don't open them.  :2cents:
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
« Reply #2 on: August 09, 2010 - 01:38:31 PM »
Certainly good safety measure but I don't really feel it's necessary for a hard top car in good condition. The roof ties everything together for structural support. A vert and really rusty cars is a must do having door support.
I moved my car 180 miles on a trailer just like in the picture. The only thing added was angle iron put on to box the legs together.
Offline daveh
« Reply #3 on: August 09, 2010 - 02:18:42 PM »
Yes, the doors are on the car but will be removed eventually to repair the rust around the hinges.  But I do plan on  replacing the doors with bracing.  I have already welded in sub frame connectors already so that should help.
BTW - The Challenger is a convertible
Hey does anyone have any old crappy hinges that I can use to weld up some bracing?
 Thanks
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« Reply #4 on: August 09, 2010 - 02:59:54 PM »
This is how I solved it, have more pics if you need.
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
« Reply #5 on: August 09, 2010 - 03:20:35 PM »
Here are what the door re inforcements look like. I'm sure with enough creativity you could make your own.
http://www.autotwirler.us/catalog/popup_image.php?pID=46\')
Offline dutch
« Reply #6 on: August 09, 2010 - 06:30:49 PM »
I made a small frame that bolts in place of the k-member.  I wanted the dollywheels as close as possible to the position of the wheels. It does help when adjusting panels.
*** Bart ***
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #7 on: August 09, 2010 - 06:51:11 PM »
Sorry I dont have a picture of just the wheel setup but you may get the idea.
if your close to Kansas City you can barrow my setup  :bigsmile:
Go Fast & Have Fun...
Offline daveh
« Reply #8 on: August 10, 2010 - 01:11:18 PM »
Awesome thanks Guys
