Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Still overheating!!!! *%&$@#!
« previous
next »
Print
Pages:
1
2
Author
Topic: Still overheating!!!! *%&$@#! (Read 5253 times)
72 cuda
Jr. Member
Re: Still overheating!!!! *%&$@#!
Reply #15 on:
August 21, 2010 - 04:00:24 PM »
Just to chime in,there is a additive to the radiator you can buy at NAPA that turns yellow in the presence of O2.
I believe it comes as blue.
If it turns yellow you have a cracked head or gasket or thin wall crack.
For the money (6 bucks ) why not?
Mark
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #16 on:
August 23, 2010 - 04:35:04 PM »
Jeff, How'd you make out?
I have a clutch fan set up kicking around to try if You don't want to take the Barracuda apart.
Tom
Logged
Tom
torredcuda
Sr. Resident
Epping NH joined 11/23/03
Reply #17 on:
August 23, 2010 - 07:16:28 PM »
Didn`t have time over the weekend.
My buddy also suggested the dye to make sure there is still not a leak.We just did the head gaskets but there may be a crack somewhere?
Tom,maybe I`ll take you up on borrowing your fan setup and we can buff out your scratch at the same time?
Logged
Jeff
72 Barracuda 340/4spd Torred
70 roadrunner 383/auto In-Violet
70 Duster 360/auto drag car (Petty Blue soon)
04 Ram 2500 5.7 Hemi
ntstlgl1970
Resident
T a c o c a t
Reply #18 on:
August 24, 2010 - 04:58:51 PM »
If you or a buddy has access to a 4 gas (i.e. smog machine) analyzer, you can use that to sample the air in the radiator. A blown head gasket/crack etc. will show a couple hundred PPM of hydrocarbon on start up cold and change if you rev the engine up. The fluid color change test (the napa fluid mentioned) is reliable as well.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #19 on:
August 24, 2010 - 06:00:28 PM »
put a pressure tester on the cooling system & see if it drops
Logged
torredcuda
Sr. Resident
Reply #20 on:
September 09, 2010 - 06:16:42 PM »
Checked out the radiator for CO and it came up negative so no head gasket leak or cracks in cylinder head or block.Tomorrow night we`ll give the tune up a once over for timing/fuel mixture etc. and go from there.
Logged
Jeff
4 speed fish
Full Member
Reply #21 on:
September 09, 2010 - 06:45:13 PM »
My 440 has a MP aluminum water pump housing,OE Replacement 26'' radiator,mopar shroud,clutch fan 5 blade,180 ts.Car runs cool all the time. CP, does the cam play a part with the heating problem of some cars?
Logged
1970 RT Challenger 1970
Full Member
Reply #22 on:
September 09, 2010 - 06:54:57 PM »
I run an electric fan on the 440, no problems idling, cruisin', etc. She runs cool.
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
