I just installed a 440 in my 70 cuda. I put a .509 cam shaft in, and heavy single spring with damper valve springs. It has six pack rods and stock 452 heads. Well my problem is i have this awful knowcking sound. I have changed the lifters and cam to a .454 and i have changed the pushrods and rocker arms. And i still have the knocking sound. I have also check my valve springs and they dont bottom out on the valve guides. So any help would be great because i am leaving for the marines and i need it running good before i leave. My next move is to check the valves, they might be bent. Any one have any experience in a .509 cam and the clearance. I am thinking that it was to much lift and made my pistons smack the valves which caused the valves to be bend. Which could be my knocking sound if the valves cant close all the way. But this is just a guess. Please help!!!!
I have always wanted a 440 in my cuda!!
Now i am having second thoughts!
Cuda383 (Now Cuda 440 KNOCKING)
