I am having some trouble with the # 7 cylinder (440) not firing. The cylinder is flooding. I have ran a compression check, all cylinders were the same with the exception of that one being down 30 psi. I squirted 10 cc of oil in spark plug hole and ran compression test and compression was back up. I have ensured that there is spark in that plug. Changed all plugs. I have changed around plug wires to make sure that there was nothing wrong in that wire. I pulled the air bleeders out and the idle bleeder on the rear drivers side was clogged. Cleared, tried again, still not firing. Pulled valve cover and appears that rockers are moving up and down the same amount on all. Pulled carb off and adjusted the butterflies so that they are all showing a small (square sized) gap in the transition way. Set all fuel mixture screws the same. Idles well. I have not checked to see if maybe a valve is sticking, I guess that will be next. What can I try next? Thanks!
