Author Topic: 742 and 489 rear chunks question  (Read 1077 times)
Offline shadango
« on: August 13, 2010 - 03:41:35 PM »
I found what I thought was gonna be IT.....a whole rear end (less brake hardware and drums) for a 66 Charger......3.55 and suregrip.
I assumed it would be a 742.......turns out its a 489.
The 489 cases were later, werent they? IE, this axle is from a 66 charger but the chunk has been replaced...right?   Or did 489s go back that far?
Re: 742 and 489 rear chunks question
« Reply #1 on: August 13, 2010 - 04:32:37 PM »
489 is the newest. Someone installed it. It is a good unit. All 30 spline
Offline shadango
« Reply #2 on: August 13, 2010 - 04:58:20 PM »
I am looking specifically for the 742 because I want the rebuildable clutch-type sure grip, and also dont want to deal with the crush sleeve stuff (I know they can be replaced with a spacer)...
« Reply #3 on: August 14, 2010 - 02:01:31 AM »
I have a 489 with a clutch. But I built it myself. And used doc differentials solid sleave in it. Works very well.  You do know a good cone sure grip will last years right?  As level headed as you act, I would think that either system will be good for you. You seem to go the extra mile on taking car of what you have.
Offline shadango
« Reply #4 on: August 14, 2010 - 07:54:20 AM »
Thanks Moparal.  Dont know that I am skilled enough to build my own.
I know that a cone type will last, especially under the use I will be subjecting it to.....but I am looking at used so I wont have a good idea of how good it is......and I have heard that refurbishing a cone type , while doable, is tougher.
Didn't know that a 489 could use a clutch type?  thought that 489s had to have the cone type and the 742 had to have the clutch type....therefore figured that if I could find a 742 with suregrip, it would have the clutch type already in it, and if it needed rebuilt, at least it was one that could be readily rebuilt.
I know....I think about stuff too much....LOL.....but I think i will hold out for the 742/clutch type a while longer......I am eager to get the rear chunk swapped in, for sure.....could just spring for a $1000 unit from Dr Diff....and still might.....
Ideally I would find a 742 with clutch type and 3.55s, in nice shape ready to drop in for a low price.....LOL......that requires a perfect alignment of all the stars.
Offline tactransman
« Reply #5 on: August 14, 2010 - 10:06:12 AM »
If you get a used 489,you have a very good chance that it will be worn out. I understand where your coming from. :2thumbs:
Terry-tactransman
Union, Mo.
