Author Topic: will it fit 318  (Read 3034 times)
Offline coupman35
  • It going to be FUN
will it fit 318
« on: August 13, 2010 - 05:12:32 PM »
Just woundeing it i can used any 340 or 360 4 Barrel intake and bolt it on my 318cu it is a 1966 motor so it may ot fit .Any one try it before they say a 318 is a ploye motor  just like to no thanks
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Offline Cooter
    • christinecarclub.com
Re: will it fit 318
« Reply #1 on: August 13, 2010 - 06:56:12 PM »
The Commonly referred to as the world famous "Big Block 318", or "Wide Block 318" An "LA" intake will NOT fit a Poly engine...The intakes are WAY different...BTW: an original 4BBL intake for the poly engine will run around $450.00,,And the Dual Four version (1957 Fury only), will be even more expensive...Save your money and swap out that old Poly and repalce it with a later model "LA" Style 318-340-360...MY .02
Offline coupman35
Re: will it fit 318
« Reply #2 on: August 13, 2010 - 08:48:11 PM »
ok how can i tell if it a poly motor. this is some number that are on the motor  2536030 -318-8  and on the other side it 10-4-66  N  can you tell whit this number what it is it look like a small motor .How can i tell if it one any special mesurment i can do or any thing stand out .
Just google the number look like it a LA motor
« Last Edit: August 13, 2010 - 08:55:52 PM by coupman35 »
Offline acudanut
Re: will it fit 318
« Reply #3 on: August 13, 2010 - 08:53:40 PM »
 a Picture wlll solve this instantly.
Offline coupman35
Re: will it fit 318
« Reply #4 on: August 13, 2010 - 09:05:06 PM »
ok you got it
I did change the water pump and other front parts used the one from my 73 block.
« Last Edit: August 13, 2010 - 09:06:49 PM by coupman35 »
Offline cudazappa
Re: will it fit 318
« Reply #5 on: August 13, 2010 - 11:03:09 PM »
10-4-66 would indicate a 1967 Model year 318.  1967 was the first year for the LA 318, primarily in Canada.  68 it replaced the 273 in just about everything in the US.
BTW: according to your picture you have an LA 318.  So a 340/360 intake will essentially fit.  There will be some slight port mismatch, but its nothing major unless you are doing a serious build.
2015 Dart GT - Daily Driver
Offline acudanut
Re: will it fit 318
« Reply #6 on: August 14, 2010 - 09:56:42 AM »
 Yea, That's not a poly, so your in luck !!
Offline coupman35
Re: will it fit 318
« Reply #7 on: August 14, 2010 - 11:29:38 AM »
Thanks for the help guys  :2thumbs:
Re: will it fit 318
« Reply #8 on: August 14, 2010 - 12:08:25 PM »
With all the internals being 2bbl cam, small valve small port heads, just adding a 4bbl isn't going to give you much of nothing except looking at it. Welcome to the wonderful world of Horse Power break your wallet syndrome. You need to do some reading up on La performance engines and ask a lot of questions before you go any further. You are just getting a nibble on a contagious hobby that will cause you to spend more money than you can imagine :money:
Offline coupman35
Re: will it fit 318
« Reply #9 on: August 15, 2010 - 06:36:52 PM »
Thanks Moparal Am also looking at a 360 just waiting and looking around to see whats for options.
