Author Topic: My 1970 Challenger R/T - Now a Customer Car  (Read 18826 times)
Offline ChallengerGary
    • Challenger Gary
« on: August 14, 2010 - 09:27:17 AM »
Here we go.  This thread will follow the build of my personal 1970 Challenger R/T.  It has the numbers matching 383 but the tranny does not match.  I bought this car back in 2005 before moving to TX was even a thought.  5 years later, I still have the car and have accumulated most of the parts to fix it up.
It was originally an FK5 Burnt Orange Metallic car with white vinyl top and burnt orange interior.  Since it does not have the fender tag or build sheet, I had originally decided to convert the top & interior to black for ease of cleaning and parts availability and paint the car Burnt Orange.  Since my life situation has changed, I have decided to go ahead and change the color to FE5 Rallye Red for resale purposes.  Unfortunately, I lost a bunch of pics I took of the car when I first got it due to a computer crash but I will post those that I have.
« Last Edit: November 18, 2010 - 08:27:51 AM by ChallengerGary »
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
    • Challenger Gary
Re: My 1970 Challenger R/T
« Reply #1 on: August 14, 2010 - 09:32:35 AM »
There's a bunch more pics I do have but I will need to re-size them in order to post.  I've got to get busy at the shop, so More to Come later tonight
    • Challenger Gary
« Reply #2 on: August 16, 2010 - 10:15:41 AM »
Some more recent pics - car is sitting down in the weeds because the torsion bars were toast so I tossed them...
    • Challenger Gary
« Reply #3 on: August 16, 2010 - 10:21:15 AM »
Saturday I installed new torsion bars and cut out the rust that was in the driver side lower qtr.  Gonna bust some tail on it today.  Should be able to make noticeable progress.
    • Challenger Gary
« Reply #4 on: August 17, 2010 - 09:35:49 AM »
Yesterday, I pulled all of the parts out of the interior.  Swapped out the bad hood hinge.  Stripped the hood down to bare metal due to some surface rust.  Sprayed 2 coats of Urethane Primer on the whole car (except area that still needs rust repair).  Ordered the needed patch panel.  Then started to clean up the steering column and install new turn signal and ignition switches.
Today, I have a few stripe kit orders to get out and then I plan on pulling the fenders and doors in order to shoot the jambs tomorrow. At the same time, I am going to repair the worn out lower door hinge on the driver side.
Offline badash
« Reply #5 on: August 17, 2010 - 10:05:50 AM »
looks like you are moving along.... :2thumbs:
    • Challenger Gary
« Reply #6 on: August 17, 2010 - 10:16:26 PM »
Did some block sanding on the hood & fenders. Then pulled the hood, fenders and doors.  Replaced the door hinges with new ones since they were pretty worn out. Then  sanded and painted the engine compartment and inner fenders & frame rails.
« Last Edit: August 17, 2010 - 10:21:38 PM by ChallengerGary »
    • Challenger Gary
« Reply #7 on: August 17, 2010 - 10:17:58 PM »
Pics of the frame rails & inner fenders
Offline 74chall
  • Mopar or No Car
« Reply #8 on: August 17, 2010 - 11:04:21 PM »
You knock Chit out mang. I like!  Gota keep the ball rolling ,motovation is key. And seeing progress keeps that going!  :2thumbs:
    • Challenger Gary
« Reply #9 on: August 19, 2010 - 10:12:11 AM »
Yesterday, I cleaned and undercoated the inside of the fenders.  Also undercoated the inner fenders. Then, painted the door jambs and inside of the doors plus the underside of the hood. Today, I will be concentrating on my customer's 72 Charger.  Going to finish wet sanding & buffing it and possibly start the exterior re-assembly
    • Challenger Gary
« Reply #10 on: August 19, 2010 - 10:14:08 AM »
One more pic from yesterday...
Offline DAYLEY/CHALLENGER
« Reply #11 on: August 19, 2010 - 12:56:29 PM »
Progress.................. :2thumbs: :2thumbs:  What color is that.......I thought you were doing Red........Might be this monitor.........Looks almost like burnt orange again.....
Dave or David
Offline Challenger6pak
« Reply #12 on: August 19, 2010 - 11:37:55 PM »
I think it is just the way Gary's camera is picking up the color.  It looks dark orange on my monitor also.  When he gets the Challenger done and outside the color will look red.
    • Challenger Gary
« Reply #13 on: August 20, 2010 - 09:03:42 AM »
The color is FE5 Rallye Red - my camera on my phone has a hard time picking up the color inside the shop
Offline 70shaker6pk
« Reply #14 on: August 22, 2010 - 07:46:22 AM »
Now that's some quick work,,  Looking great!!!!
'JS23V0B'  1970 Challenger R/T N96 440 Six Pack
