Easy there Robert...
Here's some more reading, hopefully it's just a bushing.?.?
Tom
Oil Recommended: GM Synchromesh, GM part number 12345349 (3 quarts). Optional fluids are Dexron II E and Mercon Synthetic.
Clutch: In order to maintain correct clutch adjustments, an adjustable clutch cable/quadrant kit is recommended. This will prevent hard shifting, gear clash, and premature wear of the synchronizer rings.
Transmission gear rattle may be heard under heavy loads at low speed, during cancellation, in neutral, and sometimes under wide open throttle.
Mis-calibration of the clutch-driven plate or the crankshaft balancer may be the cause. Usually, no cost-effective correction is available.
Shift Lever: Backward installation will give you an awkward, long reach.
If the upper shift lever is installed without the rubber isolator or with a modified shifter lever, the transmission will sound very noisy.
Use of any aftermarket shifter may result in gear noise or gear failure.
There is tons of additional information at
http://www.5speedTransmissions.com.
