Good morning Robert -
Please read this - This is from a post over on Moparts...
The Spec Stage 3 clutch set-up is a nice peice,...I'd toss the Aluminum flywheel though, too light for street use, Keisler has steel SFI flywheels for internal/external balance,....I run 4:10's with my Keisler TKO 600/650 5 spd .064 OD in my Daytona,...top end is 140ish MPH, street performance is awesome with that gear (running 440-6, 450 dynoed HP),......my car is running Keislers prototype 2nd gen B Body TKO 600/650 (2004 unit), it's pretty much the same unit you have,...I'd recommend you use the factory 4 spd hump, and split the floor hump accordingly so you can tuck the tranny up to proper height, confirm what your exsisting driveline/transmission angle is before conversion, mock up just the bell and tranny to see what you need to modify on either the floor or tranny case to obtain the proper driveline angle using an inclination meter,...do dial in the bellhousing to within .001-.0015, I'd recommend that if you have the older style hyd master cylinder, you should upgrade now to the Keisler/Wilwood modified master and bleeder spplied line, the HYD. TOB supplied is fine,...but the older master supplied isn't up to snuff, run Blue Racing Fluid, (VW Audi Porsche dealership), also recommend you cover the stainless braid hyd line with hi-temp spark plug insulation, esp in a header application....your tranny probally has the older Gen 1 or 2 shift tower, I'd strongly recommend an upgrade to the Gen 3 shift tower, much better unit, smoother shifts, more positive detent, eliminates the shifter "buzzsaw" vibration some customer experience at certain RPM ranges with the older stlye shift towers,...when installing the TKO 600 in your B body, remove the shift tower, 2 bolts, it makes installation that much easier, just be sure the FLAT of the shifter nub is facing towards the drivers side, as it is easy to install the shift tower 180 degress off, resulting in your shifter location being off,....the shift tower will be relocated in your install, Keisler has offset brackets to relocate the shifter to "factory" location,....bench or console
