the torque spec is 250 ft lbs , if it is a 489 carrier it will have a crush sleeve , if you take the yolk off the crush sleeve has to have exactly the same pressure on it or you will have a problem with the brgs . It is best to either replace the cruh sleeve & start again or install a spacer & shims . The 7260 is 2.125 inside ear to ear , the 7290 is 2.625 inside ear to ear
