Author Topic: Torque converter going bad  (Read 898 times)
Offline mrcuda
« on: August 16, 2010 - 03:28:51 AM »
How can you tell the signs of the torque converter going bad?
Offline Supercuda
Re: Torque converter going bad
« Reply #1 on: August 16, 2010 - 10:09:53 AM »
Worn bushing rides will leak at the front of the trans; the failure of a convertor in the "freewheel" mode (never stalls) will suck fuel and not accelerate; if stuck "stalled" it will have awesome acceleration (to a point) and suck fuel. Basically, if the convertor has failed, ugly things will happen, with obvious outward signs. Your car will be sluggish and suck fuel, and won't act properly. What are your symptoms?
Offline mrcuda
« Reply #2 on: August 17, 2010 - 04:03:27 AM »
Didn't pull off the pan yet, but when moving off you can hear a sound that seems like something is grinding. If you feather the throttle the sound goes away. At cruising speeds you don't hear it anymore. Drives fine on the highway. Noticed that going up a hill car felt like it wasn't going to make it.
