Removing engine and tranny from the bottom
Author Topic: Removing engine and tranny from the bottom  (Read 2373 times)
Re: Removing engine and tranny from the bottom
« Reply #15 on: August 20, 2010 - 09:08:54 PM »
I would have said the same thing, but it sounds like he doesn't have the equipment handy.
 :iagree:   Thats why I said top. It sounds to dangerous for a first time and not enough propper equipment
Offline WiggyHD
« Reply #16 on: August 21, 2010 - 11:21:33 AM »
We have an equipment rental place here, but I don't know if the have a hoist big enough.  Most engine hoists I have seen are rated 1000 to 1500 pounds.  Is that enough to lift the front of the car high enough?  If it is, my ATV lift will support the engine/trans so I can roll it out and lower the front onto jackstands.  Or, maybe I will just disconnect everything and take the radiator, grill, etc.. out and take it out the top.
I'll let you know what I can find to rent and see what you think.
Mark
Retired Air Force/Disabled Vet
1972 Challenger JS23H2B
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #17 on: August 21, 2010 - 11:50:49 AM »
you need a cherry picker,,i built mine but you can buy one for a reasonable price this link shows one
http://www.tool-sale.com/neiko-model-20151-ton-folding-cherry-picker-p-1837.html
« Last Edit: August 21, 2010 - 11:57:42 AM by 72rtchallenger »
72rtchallenger
what happens in the garage
stays in the garage
Offline 72 cuda
« Reply #18 on: August 21, 2010 - 03:16:42 PM »
Will this same procedure work for installing a new (k) member?
Mark :feedback:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #19 on: August 21, 2010 - 05:25:12 PM »
Yes
Go Fast & Have Fun...
« Reply #20 on: August 24, 2010 - 11:01:00 AM »
I have done 1/2 a dozen without a cherry picker , just put tall stands uner the front of the leaf spring hangers & use the diff & extra weight in the rear oft the car to counterbalance the the weight & lift the nose of the car by hand & have a frind ratchet up & stand to hold the nose up whilel yopu roll the engine under the nose of the car , then let the nose down & install the 4 K fdrame bolts & tranny X member boplts & jack up the nose of the car & tighten up all the bolts
