Author Topic: BODY PLUGS  (Read 1964 times)
BODY PLUGS
« on: August 19, 2010 - 04:08:03 PM »
Most of the plugs are rubber obviouslly but some are plastic.  Where do the plastic ones go?
There is a plug on the firewall on the electric washer cars where the foot pump would mount on a manual washer car.  Is that plug rubber or plastic? Thanks
Re: BODY PLUGS
« Reply #1 on: August 19, 2010 - 04:33:31 PM »
If nobody chimes in here, I'll tell you tomorrow after I go over and look at mine.
Offline dutch
Re: BODY PLUGS
« Reply #2 on: August 19, 2010 - 04:50:18 PM »
there was a rubber plug on my 70.
*** Bart ***
Offline JayBee
Re: BODY PLUGS
« Reply #3 on: August 19, 2010 - 04:57:23 PM »
Rubber on my '70 also, just had it off today.
John
1970 Barracuda convertible
2014 Toyota Avalon
Re: BODY PLUGS
« Reply #4 on: August 19, 2010 - 05:04:08 PM »
Thanks guys
There are a few plastic plugs in the kit I have.  Where would those go?  I can pull the plastic ones out and get their diameters if need be.
Offline Confederate Cuda
Re: BODY PLUGS
« Reply #5 on: August 19, 2010 - 05:39:56 PM »
On a Cuda the plastic ones go in the trunk area, two over the plate light. I can't remember where else and I have no idea on a Challenger as I have never owned one.
Offline dutch
Re: BODY PLUGS
« Reply #6 on: August 19, 2010 - 06:31:43 PM »
front side of rockers was plastic too. ( inside front wheelwell)
*** Bart ***
Re: BODY PLUGS
« Reply #7 on: August 19, 2010 - 07:48:07 PM »
The cap in the trunk allowing access to the top of the rear shock bolt would be plastic.
Re: BODY PLUGS
« Reply #8 on: August 19, 2010 - 08:22:40 PM »
Quote
Those are orange rubber on the 71-74's.
Re: BODY PLUGS
« Reply #9 on: August 20, 2010 - 08:57:13 AM »
I quickly realised that the body plug kit is a generic one that is supposed to fit both Cudas and Challengers.  I think I'm going to have to re-use a few of my origonal plugs.  The kit came with two different styles of large plug.  4 of one style and 4 of the other.  I think my car just used one style.
Can I get a picture of the trunk floor of a 73 that shows the four large plugs?  Preferably of one that still has the origonal plugs in it.
One more thing...I was looking through my origonal ones and found 1 plastic plug that was larger than all the other one.s  It said 1 3/8" on it when all the others said 1 1/4".  That plug fit the washer pump hole right by the brake booster.  The bodyplug kit didn't contain a new plug for that location.  So, it looks like(in 73 anyway) that plug is plastic.
Re: BODY PLUGS
« Reply #10 on: August 20, 2010 - 10:08:41 AM »
Just checked the plug to the drivers left of the brake booster & it is plastic on my '73, I don't recall any other plastic other than the drains in the trunk extensions.
Re: BODY PLUGS
« Reply #11 on: August 20, 2010 - 10:30:54 AM »
What do the four large plugs in the trunk look like?  Do they resemble the smaller plugs or do they look more like the upper shock access plugs?  Thanks
Re: BODY PLUGS
« Reply #12 on: August 20, 2010 - 03:24:01 PM »
The 4-large plugs are black rubber & have the center sunk, there are 4-smaller plugs 2-on either side behind the wheel wells that are more flat.
Re: BODY PLUGS
« Reply #13 on: August 20, 2010 - 03:27:36 PM »
It looks like I'm going to be cleaning up four of my origonal ones.  Thanks for looking.
