Author Topic: anyone else with clearance issues w/8877 edelbrock water pump???  (Read 1147 times)
Offline greenzeppelin
  • Thank you all for your help, its much appreciated!
well i had the whole engine back together...& what do ya know, my new water pump LEAKS!!!! :stomp: :swear: :swear:
I will attach some pics also.. but the problem ive figured is the bolt just behind the mechanical fuel pump.. the down pipe off the water pump hits & in turn will not let that lower corner seal to the timing cover...
any feedback is appreciated..
Cody
1973 Dodge Challenger 340, 4spd, 18x8 & 18x9.5
1989 Plymouth Reliant (K-Car!!) 2.5L, auto SOLD!
Re: anyone else with clearance issues w/8877 edelbrock water pump???
« Reply #1 on: August 20, 2010 - 12:37:00 AM »
couple more
Cody
« Reply #2 on: August 20, 2010 - 12:41:46 AM »
i tryed notching the neck a little more were the bolt was hitting, but still not enough clearance... & i don't want to take to much material out of the neck...
I am surrently fighting with edelbrock on this matter.. they tell me they've never heard of this problem.. so i am submitting them these and other pictures for there review...
we'll see if anything happens i guess..
once again any feedback is appreciated during this frustrating time
Cody
Offline 72cudamaan
« Reply #3 on: August 20, 2010 - 01:34:03 AM »
looks kinda like the washer is too thick.  Maybe the wrong bolt? Just suggestions, can't really tell.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #4 on: August 20, 2010 - 02:26:15 AM »
I have had constant problems with Eddys QC , they are predominantly  Chevy company & don`t seem to care , |I tried to return a 1407 carb that was missing an entire will for the fuel bowl internally , they treated me like I caused the problem & never looked after it
« Reply #5 on: August 21, 2010 - 03:43:03 PM »
well as 72cudamaan was saying.. i had come to the same conclusion..
so i pulled the bolt & yes that was a big washer!!
i tryed finding a flanged hex head 3/8-16 x 3 to cut down on how far the head came out, but no one had any!!
oh..also i have notched more out of the down pipe..
I ended up just getting a new standard bolt and normal washer..brought it all home & rigged it up to check clearnce..
wel it clears now but just barely..so i ground down the head of the bolt a little & i am going to work to borrow the grinder to take another small layer off the downpipe just for added insurance..
i will post pics when its it... then she can run!!!!!
Cody
