Author Topic: what needs to change to get 440 fit into 318 70 barracuda w/PS?  (Read 10979 times)
Offline tahoemuk
Re: what needs to change to get 440 fit into 318 70 barracuda w/PS?
« Reply #15 on: August 29, 2010 - 01:20:16 AM »
I found a 70 4 speed- they guy says its in decent shape, but for the 100 bucks he wants I wonder if its even worth getting or should I try to find a certain year/model manual tranny for the 440 and what year 440 makes a good donor motor?
« Reply #16 on: August 29, 2010 - 01:18:38 PM »
69-78 are the best 440 blocks , 66-72 have the steel crank if you are not stroking it
Offline acudanut
« Reply #17 on: August 29, 2010 - 07:35:16 PM »
What's wrong with a 67-68 440 Block ?
Offline acudanut
« Reply #18 on: August 29, 2010 - 07:36:48 PM »
Even a core is worth that much.
Offline DocMel
« Reply #19 on: August 30, 2010 - 05:02:20 PM »
If not mentioned already
BB  Torsion bars
BB rear springs
Offline 71chmark
« Reply #20 on: August 30, 2010 - 07:48:06 PM »
BB  Torsion bars
BB rear springs
You don't need these.
I may be schizophrenic,
but at least I have each other
« Reply #21 on: August 31, 2010 - 08:31:12 AM »
the early block is missing the re-inforcement rib at head bolt depth on the outside of the block & is a slightly weaker design
Offline acudanut
« Reply #22 on: August 31, 2010 - 12:39:57 PM »
YES I AGREE.. I have done at least a dozen of these cars..Going from a SB to BB.
YOU DON'T NEED THOSE ITEMS.
Offline tahoemuk
« Reply #23 on: September 02, 2010 - 11:11:56 PM »
thanks again. I found quite a few rv 440 motors in my area. One guy is basically giving me one with less than 2000 miles on his rebuild I have to pull it. my question is do I want one of these or what motor should I look for year, casting numbers etc?
I had an column auto so I dont have the clutch pedal setup, so my question here is do try to find a 727 auto or do I want to go with a manual of some sort while I'm making such a big change anyway- in for a penny in for a pound right? I think I can source a 70's era chrysler 4 speed in my area pretty easy if that is the right choice. I once put an aftermarket B&M cheapo shifter in my 67 firebird (which was a column auto) and I never really liked it. but it was my first car and I hacked it up so bad I wished I left it stock.
 I just want to make sure I make the right choices now so I dont have to do it twice on this really nice car (I've learned way too many things the hard way)
« Reply #24 on: September 03, 2010 - 02:36:31 AM »
nothing wrong with the RV 440 as long as it is not an industrial version where the water pump mounts to the heads , even if it is the block can still be used just the heads will not
Offline tahoemuk
« Reply #25 on: September 06, 2010 - 04:28:14 PM »
i found a 400hp built 440 and 727 reverse manual 727 for 2500 on craigslist, or should I go with a 4 speed and deal with the linkage problems with the clutch pedal. I love a manual, but I've never seen a reverse manual auto in action so I dont know if that is the best of both worlds like I've heard. Bear in mind it comes with a 3000 stall converter and will be used only for street use- thanks in advance
« Reply #26 on: September 07, 2010 - 07:28:25 AM »
I never learned how to drive an auto so I would go std
depending on the gear ratio 3000 may notr lock up on the highway which can make a lot of excessive heat
