Author Topic: 489 vs 742 Yoke?  (Read 612 times)
Offline Glennster
489 vs 742 Yoke?
« on: August 20, 2010 - 09:47:01 PM »
 I just got my 489 Pig installed. When I went to bolt the drive shaft to the Yoke I found that it was 1/2'' wider than the Yoke on my 742. I never thought to measure them....Another rookie mistake.
 Will the 742 Yoke fit in the 489 Pig?
Offline FJ5_440
  • Wisconsin
Re: 489 vs 742 Yoke?
« Reply #1 on: August 20, 2010 - 09:55:18 PM »
It would bolt right up if you get a "conversion" U joint.
** Shane **
« Reply #2 on: August 20, 2010 - 11:55:58 PM »
I would just get the Precision conversion joint , , it is the easiest fix , it is possible to swap the yolk maybe but there are 2 different splines & you upset the crush on the crush sleeve pressure removing from the 489 so I would leave it alone
Offline Glennster
« Reply #3 on: August 21, 2010 - 07:06:59 AM »
 Thanks!
