Author Topic: wheel alignment question  (Read 1275 times)
Offline barryv
« on: August 21, 2010 - 06:27:41 PM »
hi, i just brought my 72 cuda into- tire plus  - for an alignment after i rebuild front end completely with moog parts. they told me to properly align i would have to get upper control arm cam bolts that are adjustable.does that sound right and are the com bolts that are in my upper control arms different then what they sell nowadays.thanks for the help
Re: wheel alignment question
« Reply #1 on: August 21, 2010 - 06:40:37 PM »
Images of replacements are the same as the OE parts...unless someone removed the proper pieces from yours.
Rock-Auto calls this an alignment kit under suspension
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #2 on: August 21, 2010 - 07:56:20 PM »
 :iagree: you should take a close look at them,,I had one shop tell me I had the wrong tie rods sleeves because the sleeve had left handed threads on one side and he had to take the end loose to adjust it properly,,of course he was wrong so I just took it to a better shop as the sleeves were original parts,,older than he was lol
72rtchallenger
what happens in the garage
stays in the garage
Offline barryv
« Reply #3 on: August 24, 2010 - 07:50:42 PM »
thanks for the replies
