Author Topic: '70 440 oil leak  (Read 2261 times)
Offline rkh3
  • Newbie
  • I love YaBB 1G - SP1!
'70 440 oil leak
« on: April 12, 2002 - 06:33:34 AM »
It is dripping from the bell housing. The rear seal was replaced recently, so it can't be that.
If I drive it going hway speeds up hills I can see a little smoke coming from under the car, when the car levels off, the smoke stops? Could just be the angle that causes the oil to hit a hot area?
Any idea guys?
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Re: '70 440 oil leak
« Reply #1 on: April 12, 2002 - 09:53:50 AM »
 It could be a lot of things, I chased a small leak similar to that for a year 24 years ago it turned out to be a crack in the oil sender fitting at the rear of the engine that would drip into the bellhousing & spin offf the flywheel onto the exhaust  ::)
