Author Topic: Yoke & U Joint sizes?  (Read 1235 times)
Offline Glennster
« on: August 22, 2010 - 06:50:01 AM »
 When I removed my 742 Pig and went to a 489 Pig, the 489 Yoke was about a 1/2'' wider and it looks like the diameter of the caps for it need to be larger. Can anybody tell me the correct size for these? I think the part of the U Joint that fits in the 489 Yoke should be 1.125'' x 3.620''. Is that right?
The U Joint that came out of the 742 (on the Yoke side) had a cap that measures 1.075''. The part of the U Joint that fit in the drive shaft is 1.125''.
  If the 489 requires a 1.125'' cap, will I need a different strap to hold it in the Yoke or will the one from the 742 that held a 1.075'' cap be OK?
 Sorry for all the goofy questions.....THANKS for any help I can get!
« Last Edit: August 22, 2010 - 07:03:47 AM by Glennster »
Offline heminut
Re: Yoke & U Joint sizes?
« Reply #1 on: August 22, 2010 - 12:09:05 PM »
You will have to get the correct straps for your yoke, the smaller ones won't work. The Carquest I used to work at had strap kits (straps & bolts) available for the different yokes, and I would think that any good parts store should be able to hook you up with the right kit.
1970 5.7 Hemi Cuda
Alaskan_TA
« Reply #2 on: August 22, 2010 - 12:10:47 PM »
Conversion U-joints are also available so you do not need to change your driveshaft.
Offline Glennster
« Reply #3 on: August 22, 2010 - 10:06:06 PM »
 The difference between the two yokes is quite small. measuring from center of bolt holes on the two Yoke is as follows:
The 489 is 1.547''
The 742 is 1.502''
A difference of .045''
I double checked the cap size needed for these two Yokes, the 489 needs a 1.125'' cap and the old 742 used a 1.070'' cap. I went to O'Reillys, they could not come up with a strap for the larger cap. BUT, the cap I got bolts up to either one just fine...........
 The cap size difference is .027'', an I going to stretch and stress the strap by using it on the larger cap?
Alaskan_TA
« Reply #4 on: August 22, 2010 - 10:08:51 PM »
You need the larger straps.
Try Cass if you can not source them locally;
http://www.doctordiff.com/
« Last Edit: August 22, 2010 - 10:10:42 PM by Alaskan_TA »
