Author Topic: 4 spd clutch fork??  (Read 1268 times)
Offline bradmopar
  • Mopar or no car!!
4 spd clutch fork??
« on: August 22, 2010 - 10:26:00 PM »
Hi I have a 72 340 4spd. Cuda.I was trying to fix my clutch linkage and it looked like the shift fork was too long to install on my new z bar(which would explain the highly modified linkage and z bar on the car now).I removed the clutch fork and it measures about 12 1/2" long with a ball stud pivot mounted on a pedistal in the bell housing. I checked at Brewers Performance and they show a 10 3/4" clutch fork with a stamped steel pivot that mounts with 2 bolts. My question is do they make a shift fork for this pivot system in the correct length for my car or am I going to have to replace my bellhousing ,or can it modified to work with the correct set-up for my car?
« Last Edit: August 22, 2010 - 10:27:54 PM by bradmopar »
Re: 4 spd clutch fork??
« Reply #1 on: August 22, 2010 - 10:32:58 PM »
Im not sure what you got. but you described brewers part the correct way. What size flywheel and clutch do you have. I do have everything you need in my shed to make it oem. I wont be home for a few weeks to see what number is on the bell tho. I do know its a 72 340 cuda bell and other stuff
Offline bradmopar
  • Mopar or no car!!
« Reply #2 on: August 23, 2010 - 07:05:36 PM »
I called Brewers and they said my bellhousing is incorrect for my car and must be changed to make it work with factory parts. They said the bellhousing is from a overdrive 4spd from a newer Dodge truck!!!! :horse:
« Reply #3 on: August 23, 2010 - 07:58:18 PM »
make me an offer on my bellhousing.  it is off a 72 cuda.   great condition no issues
« Reply #5 on: August 24, 2010 - 10:44:07 AM »
Ball stud pivots were only used on the OD truck version so they are correct , you could modify the fork by cutting & welding & re-inforcing it to the shorter length
Offline FJ5_440
  • Wisconsin
« Reply #6 on: August 24, 2010 - 01:05:04 PM »
Are you also using the OD truck transmission?  If so, the bearing retainer is probably too big for the non overdrive bellhousing.
** Shane **
« Reply #7 on: August 24, 2010 - 06:06:00 PM »
the front brg retainer can be trimmed down to the 4.80" hole if needed
